'09 Prius now making a strange cycling noise pattern?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Christopher Jones, Feb 26, 2015.
  1. Christopher Jones
    Christopher Jones Junior Member
    the noise is not the inverter water pump could it be a 3 way valve?
    52,396
    is it the brake accumulator?
  3. Christopher Jones
    it is not the break modulator. that is a different noise. i am having issues loading the sound file. to thread.
  4. Christopher Jones
  5. Christopher Jones
    noise @
  6. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    It sounds like the Coolant Thermos pump is stuck on.
    Christopher Jones likes this.
  7. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    o_O
    When is it making this noise? In ready mode? Or when the car is off?
  8. Christopher Jones
    the noise occurs in ready mode, after coolant has cycled through the system.
  9. PriusGuy32
    1,417
    514
  10. Christopher Jones
    Could that be due to a faulty or failing 3way cooling valve?
  11. Christopher Jones
    What controls/regulates turning on and off the coolant thermos pump? Does the 3way valve control the switching on and off of the Coolant Thermos Pump? Is so could that valve be the issue.
  12. bisco
    52,396
    how many miles on her?
  13. Christopher Jones
    When I bought the car it had only 7 miles on it. I have since put 167,000 miles on it and have learned how to clearly distinguish a normal sound from an abnormal pattern of sound. This is an abnormal pattern in that it occurs for different intervals and at different times but only after the car has been warned up.
  14. enviroprius
    enviroprius Junior Member
    91
    Sonoma, CA
    It's your coolant control valve. I had the same problem last year.
