09 Prius Randomly total loss of memory and restart when turn off car
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Cheffaz, Nov 30, 2021.
  1. Cheffaz
    Cheffaz Junior Member
    32
    Woodlyn
    09 Prius Randomly total loss of memory and restart when turn off car.
    only happens when you turn off the car. not when driving.
    HV battery? Inverter? any ideas would be helpful.
    Thanks
  2. jerrymildred
    jerrymildred Senior Member
    11,508
    14,110
    Tampa, FL
    What leads to this conclusion? I'm thinking: drives rough, bad fuel economy, clock reset, radio presets gone, phonebook wiped, etc.
    At any rate, the traction battery and inverter would have no effect on anything like that. But a loose connection on the 12v might do some weird things. If you tell us what you observe, it would be helpful.
    Cheffaz likes this.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,218
    5,902
    Columbia, SC
    Everything about this screams 12v battery or 12v battery connections..........
    Mendel Leisk and Cheffaz like this.
  4. Cheffaz
    32
    Woodlyn
    I will check the battery connections later today. Thanks!
  5. bisco
    49,433
    be sure to check negative connection to body
    Cheffaz likes this.
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
    A healthy 12 volt battery in this car lives at around 12.6 volts.
    When testing 12 volt battery condition always use the front jump point. It does not matter what it measures at the battery only matters what’s hitting the front fuse box.
    If your battery is over 5 years old and has been sitting a lot from covid
    Just replace it. In the reinstallation you may discover the loose connections.
    Plus you can clean all the water out of the battery hole.
  7. Cheffaz
    32
    Woodlyn
    All connections are now tight and one seemed loose, and it hasn't happened since tightening. this may have fixed the problem, i will report back in a few days...
    nancytheprius and bisco like this.
  8. bisco
    49,433
    thanks! i hope that is it.
  9. Cheffaz
    32
    Woodlyn
    funny thing it happened once again yesterday but who knows.... could it be the hv battery dying its the original battery and I have a new optima yellow top so i know its not that
  10. ChapmanF
    15,562
    Nope, that was ruled out when you said this:
    So your issue only happens at times when the traction battery is out of the picture.
  11. Mendel Leisk
    38,705
    You could test it, or have it tested. It's a little more advanced than just a voltage test; not sure of the best term to search would be, maybe electronic automotive load tester. I use a Solar BA5, current model is BA9. Ancel comes up a lot, on Amazon. A lot of automotive retailers selling batteries will have a pro-level tester, and be willing to test for free.
  12. Cheffaz
    32
    Woodlyn
    Yes when I shutdown it will randomly turn on with memory loss
  13. jerrymildred
    11,508
    14,110
    Tampa, FL
    Unless you actually test it, you're just assuming that's not it; you don't know it. New batteries have been known to not be charged up or even be defective. But by now, unless it's defective, normal driving should have brought it up to a normal charge. But I'd still check it if it was mine.
