0w-20 oil by mistake
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Chris Vedeler, May 28, 2013.
  1. Chris Vedeler
    Chris Vedeler Red Pepper
    29
    I changed my oil yesterday and after the fact realized I put in 0w-20 Mobil 1 oil. I live in Phoenix (very, very hot) and my 2008 Prius has 145000 miles on it. I'm thinking it will be too thin and may cause problems in our heat. Should I change the oil again with 5w-30, or just run it with the thinner oil until the next oil change? We are coming into summer where the temps routinely get to 110F.
    What should I do?
  2. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    0w20 is the new standard spec for many Toyota and other manufacturer vehicles. It works from -47C to +205C. That is -52.6F to 401F.
    Don't worry about it.
    HaroldW and DU3L NRG like this.
  3. Former Member 68813
    3,524
    981
    US
    Can you hear difference in engine noise?
  4. Patrick Wong
    18,200
    6,479
    I agree that you may find the engine will consume oil at an accelerated rate. Should you find this to be the case, I suggest switching back to 5W-30.
  5. Chris Vedeler
    29
    It seems to be driving just fine. I can't tell any difference after 100 miles. I just don't want to cause any extra engine wear. It is just broken in at 145,000 miles... ;)
  6. S Keith
    S Keith Senior Member
    799
    329
    AZ
    2003 Prius
    ZOMBIE THREAD LIVES!
    For others that stumble across this thread as I have, 0W-20 will perform identically at operating temperature as 5W-20. The lower number is the flow characteristics when cold.
    0W-20 performs like 0 weight oil at cold temps and 20 weight oil at 100°C.
    5W-20 performs like 5 weight oil at cold temps and 20 weight oil at 100°C
    The higher the weight, the thicker.
    0 and 5 weight oils are BOTH thicker at cold temps than 20W at 100°C.
    20W oil is "thinner" at operating temp than 0 or 5W at cold temps.
    There should be absolutely no issues with the change and most manufacturers are retroactively specifying 0W-20 where 5W-20 was specified. The oil will always progress from "thick" to "thin" as the oil temp increases.
    Coincidentally, I have a friend's 2008, live in the Phoenix area and will be changing it for him while he's on vacation... :)
    Steve
