1. I have a 2012 Prius C Two. I know they sell a hitch for it. How much should the hitch cost to p
Discussion in 'Prius c Accessories and Modifications' started by tgpii, Jul 7, 2013.
  1. tgpii
    tgpii Member
    382
    63
    Tapier Lake/Orland Park, Ilinois
    1. I have a 2012 Prius C Two. I know they sell a hitch for it. How much should the hitch cost to purchase and how much should it cost to install? Also, how come they make a hitch but not a t connect wiring kit? (or do they make a wiring kit yet?
    1. The Prius C has no engine temperature gage. So I have no idea in the winter when to turn the heater on.
    1. Anyone know of any Prius/Toyota/Prius C clubs/shows in the Chicago, IL area?
    If anyone of these questions are in the wrong threat please direct them/me to the correct thread
  2. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    Check out etrailer.com. They sell both a hitch and wiring harness for the c. It should be very easy to install yourself if you are so inclined. Just remember the Prius has a tow rating of 0 so do it at your own risk.
    I you are worried about things like engine temp get yourself something like a scangauge - it plugs into the ODBC port and allows you to monitor a wide range of things including temp. If you plan on towing anything this is really a must have.
    tgpii likes this.
  3. tgpii
    tgpii Member
    382
    63
    Thanks, is the wiring harness plug in or do I have to cut/slice wires?
  4. stevemcelroy
    873
    194
    Boulder, CO
    tgpii likes this.
  5. tgpii
    tgpii Member
    382
    63
    Has anyone done this or am I better off just going to a shop?
  6. WD0AFQ
    WD0AFQ Active Member
    619
    152
    Dexter, Mo.
    Yes several of us have done it and created threads on the install.
    Dan
  7. stevemcelroy
    873
    194
    Boulder, CO
    You are really the only one who can answer that question. Etrailer has links to the installation instructions online. I'd recommend that you review them. If you are comfortable doing it yourself then great, otherwise bring it to someone. I installed my own on my Gen 2 Prius which included having to re-pin a Camry wiring harness as a no-cut harness did not exist for the Prius at the time. It took about 90 minutes all told. It was all fairly easy. If you do it yourself just take your time and follow the instructions.
