1 of the 2 cigarette lighters out
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by galileofigaro, Jan 16, 2019.
  1. galileofigaro
    galileofigaro Junior Member
    37
    2015 Prius Plug-in
    According to the manual a 15A fuse is for the power outlets, or, I assume cigarette lighters. Anyway, only the one located inside the center console works, the one underneath the shift lever doesn't.
    Is there another fuse I should check for the other cigarette lighter to work?
    Thanks!
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,147
    Tampa, FL
    My manual shows two fuses.
    QuantumFireball, bisco and Pluggo like this.
  3. galileofigaro
    37
    2015 Prius Plug-in
    oh, I missed number 1, thanks!
    I want to emphasize, that part of the fuse box diagram is actually confusing.
    1 should specify Auxiliary Box Power Outlet
    3 should specify Console Box Power Outlet
    BTW fuse type is micro. I temporarily used the mini kind, will work but it's a little bigger and door panel won't close.
    jerrymildred likes this.
