10' brake bleed order?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Higgins909, Nov 19, 2020.
  1. Higgins909
    Higgins909 Member
    277
    68
    NutzAboutBolts didn't seem to mention if there was a specific order to bleed brakes in. Is there?
    Thanks,
    Higgins909
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,511
    6,597
    Texas Hill Country
    The sequence of bleeding with Techstream is RR, RL, FL, FR
    Higgins909 likes this.
  3. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    10 ft is long for bleeding brakes that are close to you at arms reach.
    pjksr02 and Prodigyplace like this.
  4. rjparker
    10,511
    6,597
    Texas Hill Country
    Maybe he is a tall guy. Or he has a 2010 model.
  5. Ed Beaty
    Ed Beaty Active Member
    334
    311
    Salt Lake City
    Mendel says in an earlier post:
    "The prescribed order in the Repair Manual (and not sure if it matters, fwiw) is: FrontRight, FrontLeft, RearLeft and RearRight."
    So perhaps it doesn't matter. Always did in my experience doing conventional old school brakes tho.
    wr69, Higgins909 and Mendel Leisk like this.
  6. Higgins909
    Higgins909 Member
    277
    68
    Yes, it's a 2010 :D. I did it in the order rjparker said. Doing the rears first saved a lot of time. The brake pump was able to pump out all the old fluid fairly fast. Siphoned out of the reservoir, topped off with new fluid, bled rear right for quite a while, had to top it off again, then right left about half that. It took forever to flush the fronts. Probably 5-10 minutes each and I had help. When we got the fluid in the jug, it looked fairly brown, almost like new motor oil. I went through 1 and a half 32OZ of brake fluid... I used some autozone fluid that met the standards listed in the manual. It was clear like water.
    I also put new front pads on, it feels different so far. All of the slide pins were lubed well, as well. I was having issues with the brakes stopping too much then not enough and was essentially pumping the brakes trying to come to a smooth stop. But it would happen intermittent, so I will find out in the next week if it's helped.
    I originally wanted to just change oil, then thought I should try to flush out the brakes and then clean the slide pins to try and fix that braking problem described above. Checking pads and running out of brake fluid, it was decided to buy pads for the front. On Wednesday I got a flat, in the sidewall. I hate these old tires so I'm looking to get all new tires. Hopefully after all of that all I will need is just oil and filters... Maybe a ATF fluid change.
  7. Prodigyplace
    12,678
    11,830
    Central Virginia
    So you meant ’10 not 10’. Dyslexic much? ;)
    Higgins909 and Grit like this.
  8. Higgins909
    Higgins909 Member
    277
    68
    No, I guess I just don't know what way it was supposed to go. I always thought it was 10' and depending on context it could mean feet or year. Like I was born in 96' but you're saying it's '96?
  9. Mendel Leisk
    41,904
    Yeah the order @Ed Beaty posted is per the non-Techstream method, in the Repair Manual. Maybe not critical; but that's the order I've followed.
    I can post it tomorrow, just on phone now.
    I think the second way is right; you're truncating 1996, so the apostrophe goes where the letters were omitted.
    #9 Mendel Leisk, Nov 20, 2020
    pjksr02, Prodigyplace and Higgins909 like this.
  10. Prodigyplace
    12,678
    11,830
    Central Virginia
    That is exactly what I was saying.
  11. Mendel Leisk
    41,904
    I've never been quite sure about possessive case, "Bill's bicycle" for example. Took me 69 years to look it up, and yup;
    Possessives : The Apostrophe
  12. Mendel Leisk
    41,904
    Here's Repair Manual instructions, both non-Techstream and Techstream methods. I've only read through the "non" version, and this is the order:
    The above pic shows what takes 4 near-identical paragraphs in the manual, with acronyms-only used to describe right and left side (RH for Right Hand, for example).
    #12 Mendel Leisk, Nov 21, 2020
  13. pjksr02
    pjksr02 Active Member
    534
    227
    Connecticut
    After replacing my front pads and rotors, I used the Techstream method. Techstream(TS) sequentially tells you which brake to bleed, and supposedly the car will be all set when you're done. Of course, my dash lit up like a Christmas tree, when I was done. Fortunately, going through the TS bleed process again, but not actually bleeding more fluid, made everything right. When I replaced my rear pads and rotors, I didn't use TS!
    PS - I also came here to learn about the 10-foot-long bleeder hose!
  14. Higgins909
    Higgins909 Member
    277
    68
    Hahah, this whole time, I've been calling my Prius a 10 foot Prius on here.
  15. rjparker
    10,511
    6,597
    Texas Hill Country
    For anyone who has to watch the huge number of people who call their brakes "breaks" and quite "quiet" or seek "advise" instead of advice, punctuation is the least of our education concerns. In Texas our government is trying to eliminate standardized testing. I assume the officials are embarrassed about the results of their budget cuts.
    #15 rjparker, Nov 21, 2020
    pjksr02 likes this.
  16. rjparker
    10,511
    6,597
    Texas Hill Country
    Actually he did mention starting in the rear for the traditional reasons
  17. pjksr02
    534
    227
    Connecticut
    Since were on that subject, don't use Mobile oil in the breaks and your fine.
  18. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    o_Oo_Oo_Oo_O
  19. Mendel Leisk
    41,904
    Since weir on a role:
    People often say the fractured expression "I could care less". Think about, and you'll maybe see, "I couldn't care less" is more apt.
    Or maybe you don't care, lol.
    pjksr02 and Higgins909 like this.
  20. ASRDogman
    ASRDogman Senior Member
    7,822
    3,984
    I could care lesser! And I couldn't care even lesser!:LOL::LOL::LOL::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::whistle::whistle::whistle:
    pjksr02, Higgins909 and Mendel Leisk like this.
