10 K Service, less than impressed! dealership misery!
Discussion in 'Gen 5 Prius Main Forum' started by samsprius1, Apr 23, 2024.
  1. samsprius1
    samsprius1 Active Member
    711
    172
    2023 Prius
    Limited AWD-e
    First off I'd like to say I'm not a big fan of dealerships and I will only use them when I have to,I always do my own oil changes but as you know car comes with two years Toyota care took my car in today 7300 miles for 10k Service! In the past, normally car comes back over filled with oil but today different story technician sent me video about all the things he did including tire rotation! Pick my car up get it home look it over and I can see the tires aren't rotated. I lost a valve stem cap that was on the front right and was different from all the other three! front tires were showing outside wear? My question is where should I take this and what should I do? I don't want to get anybody fired! I know for a fact, tires were not rotated. I looked them over the night before I took the car in! Really sucks how can I trust this dealership moving forward,what else didn't they do on that checklist!!
    Gokhan likes this.
  2. Leadfoot J. McCoalroller
    7,135
    6,683
    Pennsylvania
    2018 Prius c
    You won't; they're far too desperate to keep whatever they've got.
    I just 'fired' my independent mechanic after catching him not rotating my tires (and worse.)
    Stay vigilant and try again.
  3. Mendel Leisk
    38,651
    Maybe try to talk to the service manager; he might care enough to act on it, for one reason or another.
    daisy555 likes this.
  4. ColoradoBoo
    ColoradoBoo Senior Member
    952
    626
    Monument, Colorado USA
    It is pathetic how bad some Toyota "service" departments are. I did take my 2021 Prius in for the free 10,000 mile service (even though it was her 3rd oil change at that point...I did the first two.) First issue was making the appointment (horrible on-line website), 2nd was waiting in the car for 10-minutes after driving into the bay only to be told that the real service manager would be right over...another 10-minutes! They did the service, which took WAY too long and then casually mentioned they didn't have 0W-16 so used 0W-20 (but failed to mention it's required to ONLY have 0W-16 on the next change) Anyway, got home and checked the level...WAY too much...drove on my ramps and drained it and put in 4.3 qts of 0W-16 and will NEVER take any vehicle to them, again.
    They just sent me a Toyota Survey asking me why I don't use their service department...I don't think management will like my honest answers!
    Downrange and samsprius1 like this.
  5. PriusCamper
    PriusCamper Senior Member
    11,063
    4,504
    Pacific Northwest, USA
    These tires are not only a disaster that might turn into a recall, but they exhausted the entire spare tire supply already for Gen5 Prius: Impossible to find tires for my Prius XLE AWD | PriusChat
    If I were in your situation, I'd get your documentation together from an alignment shop indicating that it is NOT an alignment issue, but a tire quality issue. Then once you get a flat, or even before you get a flat buy a new set of tires and take Toyota to small claims court for the cost of replacement tires. Also be on the lookout for a class action lawsuit because defective tires kill people and these tires have all the signs of being that.
  6. Paul Gregory
    Paul Gregory Active Member
    431
    118
    Alberta
    2024 Prius Prime
    XSE
    I'm scheduled tomorrow for my first 10K service. I'm only going back because of the free oil change. Otherwise I'd have it done elsewhere.
    PriusCamper likes this.
  7. samsprius1
    711
    172
    2023 Prius
    Limited AWD-e
    Mendel I called him back as soon as I get home and inspected the car different valve stem still on left front, the front tires had wear on the outside on the outer tread pattern you could see visibly worn more than the rears. They were never touched. He assured me he was one of his best mechanics and he had done it and I asked him to check with him and maybe he forgot?? Service advisor came back and turned it around on me like why was I questioning it making me look like a stinker?Service was extremely busy lots of people sitting around so I would maybe cut corners? I'm really having second thoughts about using this dealership again!
    Mendel Leisk and bisco like this.
  8. samsprius1
    711
    172
    2023 Prius
    Limited AWD-e
    7K miles! I didn't want to go that long on the oil but 10,000 was too much. I'll be doing 5K. I'll keep my eyes open. I watch my tires pretty close that's how I caught this guy. I'm supposed to be getting my second key next week And I can show him that the front are visibly worn and the rears are not 7K miles but I have to tell you there's a lot of incompetent people they are hiring just about anybody with a pulse !
  9. PriusCamper
    11,063
    4,504
    Anytime a Toytota Stealerships says "one of my best mechanics" looked at it or did the work, you can be fairly certain that they think they can talk their way out of something they failed to do and won't admit wrongdoing...
  10. bisco
    49,387
    i think i'd just suck it up and pay for an oil change. you'll never get any satisfaction with these thieves
  11. Doug McC
    Doug McC Active Member
    997
    374
    Midwest
    2022 Prius
    Yep! Welcome to the real world of Toyota Dealerships. Like you, I took advantage of the free oil changes (however, I change mine every 5k/6months which ever comes first). Got the last one at the dealership in February. So except for warranty claims, that’s the last time they will touch my car. If I can’t do the work, I’ll take it to a local mechanic who will allow me to watch as they do it. Several in my area are good with that.
    ColoradoBoo likes this.
  12. Uhcoustic
    Uhcoustic Junior Member
    52
    28
    2023 Prius Prime
    XSE
    Reminds me of my toyota dealership - every service/appointment I have, they leave stains on the headliner. Miserable experience in every single way.
    bisco and PriusCamper like this.
  13. Paul Gregory
    431
    118
    Alberta
    2024 Prius Prime
    XSE
    I'm scheduled for my first service at the dealer today. I plan to ask them to resolve the problem of the battery going dead every night.
    This is the second time; the first time they claimed nothing was wrong. It should be interesting.
    daisy555 and bisco like this.
  14. Gokhan
    Gokhan Senior Member
    4,618
    1,853
    Paramount CA
    Yeah, your experience with Toyota dealers will vary greatly from dealer to dealer. I tried many dealers in LA County for service before I settled with West Coast Toyota of Long Beach, which are near me anyway. Their service department is really good.
    The others that I won't name lost my valve-stem caps, even (almost) lost my coolant-tank etc. caps, put on the wrong tire (P-rated Toyo A29 instead of metric Toyo A41), wasn't sure what SAE viscosity grade of engine oil they used, etc. I am not going to name them here.
    I always check all my valve-stem caps and open the hood and checks the caps under the hood after service. So, if anything is missing, loose, or not installed, I have it corrected before I drive off. They look at me to see what I am doing, but that's better than to be sorry later.
    West Coast Toyota also has the $149.95 AdvantageCARE deal for three oil changes and tire rotations. I need to go there for service again soon.
    https://www.westcoasttoyotalb.com/advantagecare/
    #14 Gokhan, Apr 24, 2024
  15. samsprius1
    711
    172
    2023 Prius
    Limited AWD-e
    The car care nut (YouTube channel) has said in his videos he does not use Toyota care and will not take his car to the dealer for that service!
    he's a retired Toyota dealer mechanic he must know something?
  16. bisco
    49,387
    Dropping a dime on the former employer
  17. Gokhan
    4,618
    1,853
    Paramount CA
    Again, your experience will vary greatly from dealer to dealer. The main advantage of the dealers are that they (typically) use OEM parts and materials and follow the OEM specs, and hopefully the technicians are trained by the vehicle manufacturer. With certain work such as adjusting the sensors, it could be impossible to perform it at other places.
    Incidentally, Consumer Reports just rated car-repair shops, including dealers, independent shops, chains, etc.
  18. Paul Gregory
    431
    118
    Alberta
    2024 Prius Prime
    XSE
    In the aftermath of my service today, they confirmed that there is a ~300 mA parasitic drain, and the battery still tests OK. They admitted to having no solution -can't fault them for that..
    But it still goes dead overnight, so I guess my options are to keep using my battery maintainer, or buy a 100 Ah LiFePo4 battery. Unfortunately, I'm having some difficulty finding one that will fit.
    The measurements I took are: 21 cm L x 17 cm W x 15 cm H; (12,25" x 6.75" x6") Nothing exact so far. I'd hate to order one that won't fit.
    Gokhan likes this.
  19. Gokhan
    4,618
    1,853
    Paramount CA
    What?? There is no battery that can withstand a 300-mA parasitic drain. What is causing it? You need to eliminate it. The parasitic drain should be near zero.
    Downrange likes this.
  20. Mendel Leisk
    38,651
    That’s about 280 milliamperes too much. They’re stumped, have washed their hands of it? :confused:
    Gokhan likes this.
