10 years of MPG in the high 30s...What can I try?
Discussion in 'Gen 2 Prius Fuel Economy' started by kyleroden, Sep 28, 2017.
  1. kyleroden
    kyleroden Junior Member
    16
    I bought my 07 Touring new. currently at 140k miles. Over the last 10 years my mileage has always been lackluster. For a period when the car was relatively new I tried to drive as efficiently as possible and could achieve 44-45MPG on a tank at the absolute best. My commute at the time had a long stretch where I could drive 30-40 MPH. Now most of my commute is interstate. Without trying, I average 37-38MPG. I haven't seen over 40MPG in a while.
    I change my oil at least every 10k miles (it usually needs a top up these days after about 5k). I changed the spark plugs, belt, coolant at 120k. I changed the 12V battery 6-7 years ago. This is all I've done to the car.
    I believe based on being in a warm climate most of the year I should be getting better gas mileage. What can I try? Do you see anything wrong with my answers to the survey?
    I have a really cheap bluetooth odb2 interface and the torque app, if I can use that to get any information, or buy a different (relatively cheap) tool, I will
    Here's the survey:
    - Have you read This Thead Yet?
    Yes
    - What fuel economy are you getting and how are you determining fuel economy? (trip computer or manual calculations)
    38mpg average. down to 36-37 in the winter, 40 on a good tank, 41-42 if I tried really hard. I look at the MPG on the trip computer and also glance at the mileage / gas added when I fill up (They seem in line)
    - What fuel economy are you expecting and why?
    Just looking for any improvement since many people get much better milage
    - Location / outside air temps?
    North Alabama. 70s, 80s currently. 80s-90s in the summer. 30-50 in the winter usually
    - Trip patterns:
    90% of milage is daily commute. 14 miles each way. 1 mile neighborhood @25mph, 2.8mi through traffic/lights @40mph, 8.4 miles interstate @75mph, 2 mi no traffic @55mph. Relatively flat
    - Is your oil overfilled? (i.e. above the full mark on the dipstick)
    No, car consumes some oil so ranges from full to empty on the dipstick before refilling
    How old is your 12v battery? What is the voltage reading of your 12v battery after sitting over night? Battery is 6-7 years old. After ~4 hours, reads just over 12V in ACC mode, 11.7 with the fan on, and up to 14.1 in READY mode.
    Have you had your alignment checked? Any pulling or abnormal tire wear?
    Allignment done when new tires added 1 year ago.
    - Tires (16" Touring wheels):
    Michelin Defenders 205/55/R16 @ 44 PSI
    - How are you trying to drive (e.g. trying to stay in electric only?) and how hard are you braking?
    I usually don't (and don't want to) actively focus on fuel efficiency while I drive. I drive pretty averagely with the exception that I typically anticipate breaking and rarely have to brake hard.
    - Are you "warming up" the ICE (internal combustion engine) by letting it idle after powering on?
    No
    - Are you driving using D or B mode?
    D mode
    - HVAC settings? Are you using the heater, AC, auto mode, etc.? If using auto, what temp is it set to?
    AC auto when it's warm/hot out @ 77F. When it's cold out I just use the fan (AC off)
  2. SFO
    SFO Senior Member
    5,286
    4,225
    Northern California
    With 140k on the ODO it might be a good idea to clean up the MAF sensor with some MAF cleaner, sometimes that can get you a couple of extra MPG.
    That 12V battery also sounds like it could be going south, after letting the battery sit overnight measure it with the vehicle off.
    After balancing my HV battery I saw about a 3 or 4 MPG increase.
    Though it won't really improve your MPG, you might want to drain and fill the ATF WS fluid (assuming it wasn't already).
  3. Jmack111
    Jmack111 Member
    370
    78
    Tacoma wa
    Aaron Vitolins and SFO like this.
  4. kyleroden
    16
    Thanks for the reply. I've read some about people balancing their battery. I have a really cheap ODB2 interface and the Torque app that I have used for clearing codes. I'm not sure if it has the capability for checking battery cell health. What's the cheapest device I can get for that (or how do i tell if a device has that capability?) Or is it strictly a feature of the SW, and Torque can do it.
    SFO likes this.
  5. SFO
    SFO Senior Member
    5,286
    4,225
    Northern California
    Pretty sure Torque can tell you a bunch of things once set up properly and when you 'log' the real time results while driving around.
    That said, my cheapo Elm 327 BT device doesn't allow me to read the HV battery resistance for some reason -this could also be a user error on my part, as others don't seem to have this problem.
    You might want to look into a 'mini vci cable' and the 'techstream' software, which needs a windows laptop (or similar).
    What sort of codes have your logged and or cleared so far?
  6. Jmack111
    Jmack111 Member
    370
    78
    Tacoma wa
    Do the vvt first huge Difference glides much better way more power then i buy ebay cheap coils i had good luck with the cheap one pack of 4 battery show full charge way more. I really thought it was the battery but after the huge boost haven't even check it after i bought the odb2 tester
    SFO likes this.
  7. bisco
    48,946
    living in the climate you do, i don't think you can expect much more. heat is a hybrid killer. there may not be a warmer place on earth.
    i think it's amazing that you have gotten 10+ years out of the battery. i would sell the car, or put a new battery in.
    btw, your 12v is virtually dead.:ROFLMAO:
    ps, you are supposed to change your oil every 5,000 miles. you have a maintenance schedule in the o/m.
    pss, the 16" defenders have a lot in common with your poor mpg's.
    #7 bisco, Sep 28, 2017
  8. 05PreeUs
    05PreeUs Senior Member
    1,097
    563
    MSP
    The tires you have a not LRR/ULRR, they are Standard Touring models and rolling resistance is a BIG factor when trying to eek out those last few MPGs.
    Clean or dirty MAF will have virtually zero effect because these cars use Wide-Band Oxygen sensors (WB HEGO) for Air-Fuel-Ratio (AFR) control. Therefore, even if the MAF signal is WAY off, the ECM will adjust to keep the AFR in the specified range (speed and load dependent), which is typically about 16:1 for lean-burn applications where FE is the primary goal during cruise.
    Having said that, if the WB oxygen sensor is tired, it WILL affect FE. One clue is the long-term fuel trim, if it is too far off 0%, it suggests the sensor has lived it's life or been damaged by the use of silicone somewhere in or on the engine.
    Last thoughts are the driving style plays the single biggest role in FE, I consistently get 10% better than my wife around town, regardless of which vehicle. To say I drive conservatively, would be an understatement. Secondly, increasing tire inflation pressure will not off-set the substitution of standard tires for LRR or especially ULRR tires. This is mostly a highway speed FE impact, FWIW.
    SFO likes this.
  9. fotomoto
    fotomoto Senior Member
    5,597
    3,771
    So. Texas
    Answering the original question in the subject header: Why start now; especially if it involves spending a lot of money (new set of tires,etc)?
    You can either slow down or just live with it. When I had my G3, I got 46-50mpg driving mainly a 35-60mph route while my wife got 39-41mpg on her 70-75mph route.
    Edit: also, I skimmed the other posts and didn't see it mentioned but you have a 10 year old HV battery that is getting weaker and weaker which means the engine runs more and more=lower mpg.
  10. bisco
    48,946
    sounds like o/p has more time on his hands to finally try and diagnose and fix the problem, now that he is driving less, and the problem of low mpg is less important.
  11. 05PreeUs
    1,097
    563
    MSP
    Since this has been the case for some time, I doubt that is a factor as the numbers have not changed.
  12. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    His own experiences should tell him this already.
    And I agree that it is WAY too late to be worrying about this anyway.
    It likely will get worse.
    And at that point the only "fix" might be a new car.
  13. kyleroden
    16
    Thanks everyone for the feedback so far.
    A lot of feedback about the tires. I agree this is probably a big factor. One of the few diagnosis that matches the "this has been happening forever" symptom. Unfortunately, after years of buying used tires, I decided to buy some decent tires that would likely last me the rest of my time with the car. Probably not going to change this.
    I know it sounds dumb that I'm just now focusing on this. Definitely should have investigated more 10 years ago, but was just busy with other stuff. I just got the car back from my wife. She got a new car, so I do have a bit of new car jealousy and want to spruce this up. (improving the car will help keep me from buying a new car sooner). Also just looking to spend some hobby time. Not true that I am driving less, still could definitely use the MPG.
    Yes my traffic patterns and driving habits are probably another big factor. But I feel like they are not terrible, and my milage is terrible. On fueleconomy.gov, the average MPG for this car is 46.4. Do you believe that is skewed?
    Yeah probably not worth it to put a new HV battery in a 10 year old car huh? I will look into the HV battery health and explore from there
    RE: the 12V battery, Can I really expect much out of replacing this? Is there a way to tell via Toque if the HV system is wasting energy on the 12V battery? I get that it is aging and that my voltage is a little low, but I see many people have gone much longer here with their OEM battery (and I've replaced mine once)
    Seems like a pretty obscure fix? I only see this one thread and it doesn't multiple people saying "wow this really fixed my MPG". Seems like a last resort if nothing else explains it.
    Oh you know, that one time I didn't plug a spark plug in all the way. Whoops.
  14. bisco
    48,946
    you can expect something if the engine has to run more to charge the hv battery which is constantly charging the 12v through the inverter.
    but a bigger concern is getting stuck somewhere when the 12v quits. edit: 6-7 years is getting close to the finish line. test it after the car is off, and has been off for a few hours. if it isn't 12.4 or better, you can try charging it, but if it won't hold, replace it. the computers don't play nice when the voltage gets too low.
    it doesn't matter how long others have had their 12v, it only matters what condition yours is in. and in the southern heat, many replace them at 4-5 years.
    #14 bisco, Sep 29, 2017
  15. 05PreeUs
    1,097
    563
    MSP
    Not really, our '05 does that routinely.
  16. MelonPrius
    MelonPrius Senior Member
    809
    504
    Las Vegas
    If you have 15 minutes to spare, this is a test I usually do with my friends, when they're struggling to reach their mpg goals. Do a 70 mph test run on the 16.8 mile round trip, interstate portion of your commute on cruise control. I'd do the test on a weekend, or a slow period. The key is using cruise control to take the human element out. Stay in the slow lane because if the speed limit is 70 mph, you'll be among the slower drivers. Do it at a time when you can keep the AC off.
    It takes you nearly 4 miles to reach the interstate, so the ICE should be warmed up. Again, it's important to keep the cruise control set at 70 mph- the lower the better. You must do a round trip to account for changes in elevation. Start the tripometer at the beginning of the highway portion and end it at the same spot on the return.
    If the tripometer reads 50+mpg over the 16.8 miles, then the problem is probably related to driving habits. If the tripometer reads 38 mpg, then there is something mechanical that needs to be addressed.
    SFO likes this.
  17. Fredsimm
    Fredsimm Active Member
    188
    117
    Tupelo MS
    Being fairly new to Prius and the forum, I can only state that at continuous driving at 70 mph or above, my mileage can drop to the low 40's. Continuous driving on long stretches at 55 mph gets me 45.5 to 46 mpg. I also notice that stop and go driving in the city really drops my mpg. But yet my hv still runs in the green sometimes. I am finding that speed, driving habits, and circumstances do affect mpg more than I thought.
    Sezy and SFO like this.
