100k service confirmation
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by PA Prius, Nov 5, 2008.
  1. PA Prius
    PA Prius Active Member
    763
    251
    SE Pennsylvania
    I'm taking my '04 in for its 100k service on Friday. Up until this point I have changed the oil and filter, air filters, and replaced tires myself. But I'm thinking she needs a good check over at this milestone. I happen to also be going to have my 50 year physical tomorrow, so maybe it's a mid-life thing. Anyway, this is what I plan to have done. Am I missing or misunderstanding anything?
    Replace spark plugs-- I know they aren't due until 120k, but it will likely be at least 150k until I am back at the dealer.
    Transaxle fluid - replace
    Engine and inverter fluid - replace? Is this one fluid or two different ones. Mine is still nice and pink, so maybe I'll let it go??
    PCV valve - replace
    Also, what should I expect to pay for this?
    Thanks Galaxee for your Sticky in this forum.
    PA P
  2. Patrick Wong
    18,200
    6,492
    Two separate coolant loops - one for the engine, the other for the inverter and transaxle. 100K miles is a long time to have the same coolant in service; since you don't plan to have further significant work done until 150K miles, I suggest that you have both coolant loops drained and replaced now.
    Good luck with your car's service and with your physical exam.
  3. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    that about covers it service-wise.
    expect probably 4-5 hours plus parts/fluids at whatever labor rate they charge.
  4. PA Prius
    763
    251
    SE Pennsylvania
    Thanks for your assistance. I am currently sitting in the waiting room at New Holland Toyota. There were two additional items I wanted checked out before my Platinum warranty expires in 450 miles. One was the broken upper glovebox spring/hinge. It is not covered and would cost about $150. to fix, so that will stay as is. Second is the sticky shifter. It started clicking when shifting almost a year ago and now it sticks-- so we have to nudge it back to the normal resting position, otherwise it will stay in the D or R position. Mechanic just told me there is a plastic piece warped, likely from heat. Toyota will cover this under the Platinum warranty-- the whole shifter needs to be replaced, would have been about $350. for the part.
    Also, the mechanic said there is a bit of corrosion around the water pump, indicating the start of a slow leak, so he'll replace that under warranty as well. Unfortunately I can no longer say that I have not needed to do anything to this car other than routine maintenance. But I suppose 100k problem-free isn't so bad!
    The service here is very good-- nice waiting room. In addition to all the comfy chairs, there are four cubicles, wireless internet, free coffee and soft drinks. And they said I would get a free loaner if they aren't finished by the time I need to get to my next meeting. Of course I haven't seen the bill yet!
    PA P
  5. PA Prius
    763
    251
    SE Pennsylvania
    My bill was $325.50 for spark plugs, engine coolant, and transaxle/inverter fluid. Price is inline I suppose. I also asked about the PCV valve and was told in the Prius it is just an orfice and is not replaceable.
    Thanks again for your assistance.
    PA P
  6. Patrick Wong
    18,200
    6,492
    This definitely is untrue; see attached photos. The first photo shows the old PCV valve installed on the engine; must remove the engine wire harness over the engine valve cover for access.
    The second photo shows the newly installed PCV valve in upper right corner of removed valve cover (photos from my 2001; 2G is essentially the same).
  7. StephenG
    StephenG New Member
    TX
    For 100k service, would you guys recommend exchanging the brake fluid?
    Appreciate the help.
  8. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    It won't hurt it. Be aware the Prius is totally different from the average vehicle where the brake system is concerned. If you don't know what you are doing, you should learn before you start. Otherwise you might do a lot of damage to the system which will require expensive repairs to get the Prius back on the road. Rule #1 - Before servicing the brakes on ANY Prius, DISCONNECT the 12 volt battery. Also, be aware that the to properly bleed the system, normally the Techstream Software is used to do the work. The software can be found online (hacked version) or you can get it from Toyota (very expensive). Also Toyota does have a website where you can get detailed info and repair outlines for a fee. I am not sure what the URL is, but a Google search will reveal it. Patrick Wong has that info also.
    But to answer your question, exchanging the fluid would be a good idea. Especially if the PH is wrong, and or the fluid is discolored. The fluid does age over time and does need to be replaced from time to time. I am not 100% sure what the maintenance schedule is on the brake fluid. Patrick Wong should have that information.
    Best of luck to you and welcome to Prius Chat!
    Ron (dorunron)
  9. Mendel Leisk
    40,574
    The latest Canadian Prius maintenance booklet (PDF) I saw indicates tri-yearly brake fluid change. 2014 model year I think.
    Also, how about a brake inspection?
  10. Fifine
    Fifine Member
    106
    So Cal
    Part # 12204-21011, about $7-10. Maybe 1 hour labor cost since Tech will have to go back in and remove all the covers and hoses he did to replace the spark plugs.
    http://data:image/jpeg;base64,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
  11. StephenG
    StephenG New Member
    TX
    Cool, thanks Ron. I'm gonna have this Toyota / Lexus auto shop do the brake fluid, engine coolant, inverter coolant and transaxle fluid. My 08 Prius has never been serviced besides routine oil changes.. and the time I clipped a middle divide curb.
    If there's anything else you'd recommend let me know!
  12. dorunron
    3,318
    1,105
    Houston, TX
    If Patrick Wong replies, pay close attention to his post's. He knows a lot more than I do. But you are on the right track.
    Best of luck to you StephenG. What part of TX are you in? Big state for sure. All kinds of weather and topography too. Hills, valleys, flat lands, mountains. You name it, TX has it.
    Ron
