11.6 HD display frozen in navigation mode
Discussion in 'Prime Main Forum (2017-2022)' started by ArcPrime, Dec 22, 2017.
  1. ArcPrime
    ArcPrime Active Member
    201
    166
    Arcadia, California
    My 11.6 HD display frozen in the navigation, at the beginning it happened once a while, now it happened more often. Navigation was on, Bluetooth is connected to my iPhone, radio was also on. The whole HD display will get frozen, none of the button on the side worked except volume up and down. Navigation function still works in the tiny dashboard screen. Radio stayed with the station I selected. None of the sterling wheel radio buttons will work. Once I restarted the car every thing works again. Don't know if this happened to anyone else?
  2. Mark57
    2,945
    2,736
    OK
    I'd take it back to the dealer and let them see if there is a new firmware version for it.
    ArcPrime likes this.
    49,386
    check the 'constant rebooting' thread. not sure if anyone had a frozen screen problem or not.
  4. Prius33704
    Prius33704 Junior Member
    Central Florida
    Used 2017Jan Prius Four Touring reporting in. Experiencing same.
  5. Storm2019
    Storm2019 New Member
    Los Angeles
    2019 Prius Prime
    2019 prime. Happening to me too. Just took it to a dealer. Will update with dealership results.
  6. Habnar
    Habnar Junior Member
    43
    Oakley, CA
    2019 Prius Prime
    Happened to me once. After the car was restarted it fixed itself. The manual says to touch and hold the audio button on the side of the screen to reboot the screen. I tried it and it does reboot the screen. Thankfully it hasn’t frozen on me again to see if that will reset it when it is frozen.
    Storm2019 and Chazz8 like this.
  7. Storm2019
    Los Angeles
    2019 Prius Prime
    Life saver! Next time this happens mid drive at least I’ll have a way to reboot! The dealer just did a hard reset and luckily it hasn’t happened again so far.
