12 battery
Discussion in 'Gen 5 Prime Charging' started by Xse, May 6, 2024.
  1. Xse
    Xse Member
    74
    31
    Brighton Ontario Canada
    2024 Prius Prime
    XSE Premium
    Had a battery tender plugged in for a couple of days now
    Started the prime the battery gauge only shows 16%
    I taught it would show 100% when started
  2. BiomedO1
    BiomedO1 Senior Member
    4,126
    2,168
    SacTown, Ca
    A 12 VDC battery tender doesn't charge your traction battery. The plug within your right side (passenger side) fuel door does. There should be a charging cable in your trunk somewhere. It'll take 4 - 8 hours for a full charge on a 110 VAC outlet.
    Please read your operation manual........
    52,386
    There is no dash indicator for the 12 volt, you need a meter
  4. Xse
    Xse Member
    74
    31
    2024 Prius Prime
    XSE Premium
    upload_2024-5-6_16-57-39.jpeg So I understand what was said by bisco &biomed01 then the 12v symbol above the gas gauge is that the traction battery if so thanks
  5. BiomedO1
    4,126
    2,168
    SacTown, Ca
    The battery icon with the pointer next to it indicates traction battery level and which side of the car is the fill port.
    Ditto, with the gasoline pump icon.
    The lower right icons seems to indicate how many miles you've traveled on battery vs Hybrid gas power - but double check with your owners manual. Flip through your manual, I believe you can get different gauges and dash layouts.
    #5 BiomedO1, May 6, 2024
  6. bisco
    52,386
    the pic is not expandable for me, and i don't have a magnifying glass handy. what does the 12 volt symbol look like?
  7. Xse
    Xse Member
    74
    31
    2024 Prius Prime
    XSE Premium
    It’s the 12volt square battery above gas gauge
  8. bisco
    52,386
    seeing the same icon to the left, next to the traction battery, i agree with biomed01, it is the traction battery level indicator, but they sure do make it confusing.
    RandyPete likes this.
