12 miles EV after fully charged?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by evebill8, Nov 21, 2012.
  1. evebill8
    evebill8 Member
    139
    16
    San Jose, CA
    Ho folks,
    I am using 110v to charge my PIP. I start at 2:00 am, and end at 6:00 am. 4 hours total should be enough to re-charge the EV battery. However, it only shows 12 miles in the display. Is it normal?
    Thanks!
    JMD likes this.
  2. bfd
    bfd Plug-In Perpetuator
    659
    172
    Close to SDSU in the Far Southwest Corner of Cali
    It's normal. Owner data on different threads featuring this question range from the low 10s to 16s. (the 16s are definitely outliers)
    Fully Charged EV Range | PriusChat
    Just eyeballing the data, you can see that your result is pretty much in the middle. We could do some statistical tests - but the results would be the same. Your result is right in the middle of normal.
  3. 3PriusMike
    2,963
    2,314
    Silicon Valley
    The time to charge has nothing to do with how many miles it shows, as long as you did a full charge and get that message. The number of miles shown is some type of average over many previous full charges of how many miles you've gone. If it shows 12 miles on a full charge, you might get 10 miles on this charge (for example if you drive fast and accelerate hard on a freeway) or you might get 15 miles (for example driving 30 mph with minimal traffic).
    Mike
    49,371
    normal. don't go by the battery gauge, take it for an all ev drive and see how far it goes.
  5. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    Now with the colder weather in NY (some 20's in the mornings) my estimated EV range is down to 10.4mi.
  6. SJ PiP
    SJ PiP Member
    190
    35
    i set the timer to chg start at 1am and it seems to only take a little over 2 hours.
  7. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    2 hours and 34 minutes
    LG-MS910 ? 2
  8. SJ PiP
    SJ PiP Member
    190
    35
    the timer has two options: start at set time or end at set time. so i guess your actual charge is not 4 hours
  9. Adam Leibovitch
    498
    102
    "End" means it will start charging when you plug in and ends when you set it or when its full? Or it will guess when to start in order to end at that time? I don't have TOU so I just charge whenever.
  10. SJ PiP
    SJ PiP Member
    190
    35
    from http://www.toyota.com/t3Portal/document/om/OM47818U/pdf/sec_01-02.pdf:
    ■Charging timer function (finish time setting mode)
    ●The finish time setting mode should only be used as a reference for the
    time at which charging will finish.
    Charging may not complete at the finish time depending on the effects of
    the electricity supply, temperature etc. In this event, charging will continue
    until completed.
    ●If the function detects that charging cannot be finished on time, charging
    will start immediately, and will continue until fully charged.
  11. evebill8
    evebill8 Member
    139
    16
    San Jose, CA
    I extended one more hour, from 1 am to 6 am. I get 12.8 miles this morning. May be I have been getting around 12 miles, and I just do not notice it. Thanks guys!
  12. bfd
    659
    172
    While it is true that time of charge has some effect on the display - for example, charge less than two hours and you will not get a "full" charge - so the EV range will be less than 10 miles - the effect on the estimate approaches zero as time charging increases past 3 hours. Assuming you've been charging at least three hours all this time, it's unlikely that your extension of charge time affected the estimate rise this morning.
  13. evebill8
    evebill8 Member
    139
    16
    San Jose, CA
    No, it did not increase anything miles after adding one more hour. That's why I said it might have been around 12ish miles, but I just did not notice it.
  14. lensovet
    2,614
    496
    Burlington, NJ
    Note again that these are two separate timers. It's not a start and end time, it's a start time for charge 1 and a "finish by" time for charge 2. Both charges will continue until the battery is full.
  15. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    The important thing to remember is that the EV miles shown after you charge is an estimate of how far you can drive on EV only, based on your previous driving, not how long you charged, as long as it was a full charge. Then, depending on how you drive that day, you may get more or less than the estimate, because you can pick up miles by regen. You can also use up the EV miles faster, depending on driving conditons. There are other threads on this subject, if you are interested.
