12 mm tamper proof bolts for battery
Discussion in 'Prius v Accessories and Modifications' started by syscon, Jun 20, 2015.
  1. syscon
    syscon Member
    329
    42
    Edm. Alberta
  2. Air_Boss
    Air_Boss Senior Member
    3,952
    1,083
    New Yawk
    Unfortunately, any shop that sells the bolts sells the extractors... So...
  3. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    My advice would be don't get caught up in this hype. There is no fastener you can buy publicly that will stop a thief from taking your battery if they want it bad enough (or destroying the vehicle in the process). Just use common sense vehicle security practices and keep your insurance premiums up to date..
  4. syscon
    syscon Member
    329
    42
    Edm. Alberta
    I think the "Plug-in" type would be more of a target as they have much larger battery.
  5. frodoz737
    4,297
    2,348
    33
    Still won't stop them.
  6. ChapmanF
    15,659
    The insurance outcome is likely to be a 'total loss' unless the Prius is very new, as the prices of the wiring harnesses the thieves will have destroyed (even the ones that can be ordered at all) will significantly exceed that of the battery itself.
    My guess would be that, for anyone who judges this risk to be unacceptable, it would be best to design and fabricate something independently (probably including sheet metal extending over the wire harnesses, which will otherwise be destroyed before the thief even notices there are clever fasteners holding the battery down).
    Someone might go into business mass-producing such a thing and selling it, but as soon as that happened I'd be disinclined to buy it. If anything becomes common enough, thieves will just be prepared for it. Sometimes you can slow them down by creating an environment of diverse one-off countermeasures they have to take time to figure out in each instance. They don't want to be slowed down, if somebody else's Prius won't.
    OTOH, if countermeasures just change their routine to putting your Prius on a flatbed and hauling it to the chop shop, all bets are off.
    -Chap
  7. bisco
    49,504
    i think the v is the most highly desired battery, and alberta seems to be a hotspot for some reason. check your insurance to make sure you're covered.
  8. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    775
    360
  9. frodoz737
    4,297
    2,348
    33
    Yep...just another keyed fastener like wheel locks...and just as easy to remove.
  10. Avi's Advanced Automotive
    775
    360
    Did you watch the video? I'm sure you can think of a way they didn't try in it.
  11. frodoz737
    4,297
    2,348
    33
    Respectfully speaking...;)
    That was entertaining and makes the naive feel all warm and fuzzy, but as a member in good standing who runs a respectable shop, you know the only people these fasteners would stop are ignorant owners that lost their adapter.
    [ ignorant - used in context and defined as - lacking knowledge, information, or awareness about something in particular ]
    ...and for the record, the last thing I'm going to do is tell everyone how easy these are to remove. They are nothing but placebos and my previous advice stands.
    YMMV
    #11 frodoz737, Jun 22, 2015
  12. Avi's Advanced Automotive
    775
    360
    I know I could remove these, and am pretty sure I could do it with the same tools they showed in the video. They are in no way impossible to remove, however, I doubt these thieves come prepared to remove them. In reality though, If someone was going to break my window and destroy my interior, I'd probably like a new battery included in the repairs. Now, if someone only has liability insurance, complicating things for thieves couldn't hurt.
    One thing I think might be a good idea is engraving the cars VIN number on the battery.
  13. frodoz737
    4,297
    2,348
    33
    "One thing I think might be a good idea is engraving the cars VIN number on the battery."
    Another warm a fuzzy, but some people still put flimsy chain locks inside the house doors too. If folks want to take these measures that's fine, I just wanted to make people aware they won't really do any good against people that steal for a living.
  14. Avi's Advanced Automotive
    775
    360
    Fine, what about something like this:
    CatClamp Catalytic Converter Theft Prevention Lock
  15. Air_Boss
    3,952
    1,083
    New Yawk
    Buy a Yugo. Problem solved!
  16. frodoz737
    4,297
    2,348
    33
    Clicked on the first one out of curiosity. Wow, only $680 (before TTL+install) to make your cat theft "resistant". The same cat that cost $150 or so (before) in states that allow aftermarket units (not California). Who's the thief?
