12 plugin hazard lights constantly blinking
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Jake1211, Apr 1, 2016.
  1. Jake1211
    Jake1211 New Member
    New york
    Got into my car this morning turned on the car and the hazard lights started to blink . Thought I might have pressed the hazard lights button , so of course I press the button into the lower position and the lights are still on .. Then I press the button again into the raised position and put the car into drive and now the hazard lights start to blink faster as I accelerate ( now my Prius Became a police cruiser ) it's obvious I have a short some where , or the relay went bad . If it's the relay, where can I find the relay in the car ? Looked in both fuse boxes and I couldn't find it . I've since pulled the fuse on the hazard/ signal lights. I'd rather try to fix this my self before I have to pay Toyota to rob me blind . All suggestions would be appreciated .
    Thanks
    J
  2. Jake1211
    Jake1211 New Member
    New york
    Bump
    51,155
    have you checked your 12 volt health?
  4. deger
    deger New Member
    Pittsburgh
    I
    Ever find a solution to this problem? I have had the same thing happen recently and am totally perplexed
  5. 55ticoga
    55ticoga Junior Member
    Iowa
    2015 Prius Plug-in
    Also make sure that your ground cables are in good shape.
  6. bisco
    51,155
    in a pip?
