12 V Battery Drained after 6 Days!--And worse??
Discussion in 'Gen 3 Prius Main Forum' started by kgall, Jun 20, 2010.
  1. kgall
    kgall Active Member
    984
    152
    Olympic Peninsula, WA
    My wife and I just got a call from a friend of hers at the airport.
    She just came back after six days (June 14-20) and couldn't open the door to her 2010 Prius with the key fob.
    So she took out the physical key and opened the physical lock and got in. Then she tried to start the car normally. Nothing happened.
    She called us, I think because we are her only Prius-owning friends. Unfortunately, the airport she is at is several hundred miles from us, so we couldn't go either commisserate with her or check out the car, or do the recommended jump start in the owner's manual (and she doesn't quite trust herself or the person who is picking her up to do that right).
    She told us that when she pushes the buttons on her key fob, the little light there lights up, so we think the key fob battery etc is fine.
    We had her go through the drill of touching the key fob to the POWER button. That didn't work.
    That means it's probably the 12 Volt battery is drained.
    I know a few folks have reported this, but only after 13 days or more.
    Now, here's what might make this worse. Just before this happened, she noticed that the number of bars in her Traction Battery icon were jumping down the way some folks on PC have reported. Her dealer told her this was nothing and don't worry about it. I suspect this is true, because this has been while she's been in stop and go traffic in hot weather--usually with AC on--so it could be that stealth operation plus AC is simply using the battery quickly.
    But somehow I wonder--could there be some problem with the electrical system that is causing drainage to both the 12 v and traction batteries?
    She's having it taken to the dealer tomorrow.
    Thoughts and suggestions anyone? Either ideas about what's going on, or what to ask the dealer?
    [Now I think everyone who has reported this problem has left the car in a parking lot at the airport. Maybe it's airports that Prius batteries don't like.]
  2. Vancouver
    Vancouver New Member
    42
    Vancouver
    That sounds awfully quick to me. I just got back from a 2 month trip with no problems as detailed here: http://priuschat.com/forums/gen-iii...84-battery-survives-2-months-without-use.html
  3. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    Did your friend's car have a security system? they may cause excessive current drain on the 12V battery when the car is parked.
    After reading a number of these posts I am suspicious that Toyota may have gotten a batch of bad 12V batteries. The test that needs to be done is a test discharge over an 8 hour period. This is the only good way I know of to determine the actual capacity of the battery. Unfortunately the dealer will probably not be able to do such a test because they don't understand how and don't have the time. They do have a battery tester they can put on it, unfortunately the results of their tests may not be accurate, good batteries sometimes test bad and bad batteries sometimes test good.
    If the dealer tells her the the battery is good and can find no other problem she should consider taking the battery to a battery shop and having them test it also. If the problem isn't found it will almost certainly reoccur, and that usually happens at a most inconvenient time.
  4. kgall
    kgall Active Member
    984
    152
    tumbleweed,
    Thanks.
    Don't know about the security system but I will ask. What kind of security system do you mean, beyond the SKS system standard on Prius?
  5. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Something like an alarm.
  6. tumbleweed
    4,067
    687
    Eastern Oregon
    Right, as 2K1 said an alarm system. The one Toyota sells either through the port or the dealer is called the VIP RS3200, some dealers sell after market ones also. Several posters have had problems with add on security systems, remote start systems, etc.
  7. G3priusV
    G3priusV Member
    131
    17
    UT
    I left mine for 6 days in my garage last summer and it opened and started just fine and it had about 2 bars of battery which charged up so fast as soon as I started driving.
    iPhone ?
  8. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    It is possible for a failing 12V battery to drag down the traction battery.
    Tom
  9. kgall
    kgall Active Member
    984
    152
    No alarm.
    The car is being taken to the dealer now.
    Our friend has one possible theory that would make it her fault. She put one of those windshield heat shields up when she left, and she says it's possible that she hit one of the map lights above the rear view mirror and turned it on and left without noticing.
  10. tumbleweed
    4,067
    687
    Eastern Oregon
    That would do it. If she did it should still be on I think they are just click on/click off switches, maybe the people at the dealer could look and see when they hook the battery up to a charger? It would be nice if that were the problem then she wouldn't have to worry about "next time".
  11. Pb taco
    Pb taco New Member
    earth
    My battery died last Friday night. I have a stock 2010 package 3.
    I used the vehicle last about 10 pm. At 840 am Saturday, vehicle wouldn't come on and show "ready" on the screen. All the electronics were haywire.
    Following the manual, I jumped the prius with another vehicle and it can on. Of course, I'm upset about this and worry about being stranded.
    I haven't had any problems before. I normally leave the lights in the on position when I turn off the vehicle (to provide light in a dark area).
    I remember that I accidentally turned off the lights, powered down the vehicle and then turned the lights on. Did this cause the lights to burn longer and kill the battery? I thought the vehicle had a shut off so the lights could provide exit illumination.
  12. tumbleweed
    4,067
    687
    Eastern Oregon
    Yes I think you have isolated the cause. As I recall the auto off feature only works if you have the lights on when you power down the vehicle. If you turn them on with the vehicle already off they will stay on.
  13. kgall
    kgall Active Member
    984
    152
    End(?) of the story:
    The dealership took the car in and jumped the battery.
    They said the lights, etc., had not been left on, so it wasn't our friend's fault.
    And the 12 V battery is OK.
    Except that she left it too long without driving.
    Somehow, I still think six days is too short a period for this to happen in. A whole lot of people, especially city folks who are likely to get a Prius, don't drive cars for six days in a row, and expect them to start up.
    Does anyone think it's worth her taking her complaint further to the regional service dept or whoever, to see if there is an undiscovered problem?
  14. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    I think that you are right. 6 days with no unusual and avoidable power draw is way too short a time for practical car usage and doesn't seem credible.
    I would pursue it further.
  15. tumbleweed
    4,067
    687
    Eastern Oregon
    The dealer says six days is too long to leave the car without driving it! WRONG. Car should be just fine for a month or more. If there were no lights left on it means there is a sneak ckt drawing current or a bad battery.
    If it's not fixed it will almost certainly happen again if she has to leave it. I think if it were mine I would try to get someone at a higher level interested in the problem. That, unfortunately, may be easier said than done.
    2 people like this.
  16. F512M
    F512M Member
    415
    Laguna
    So for each Prius that's on the lot and not sold needs a jump to start? That doesn't sound right. Somebody is smoking.
  17. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i think its a bug. i reported here that my 2010 Pri 12 volt batt died as well, and it sat for ... well 6 days. hmm, but anyway, i jumped the battery and have not had issues with it since and that includes 2 stretches of 6 days of inactivity
    now, the door sensors are supposed to go into a sort of hibernation mode during an extended period of inactivity. this is something i have seen on my 2010 several times where it will take like 5 seconds for the door to open. wondering if the timer circuits need some work ??
    PB; i dont think jumping your Pri with another car is a good idea. i have a portable jump box i bought (used it to charge RC cars) that i used to jump mine. paid like $35 for it about 5 years ago. i guess its about to die since the batts are sealed lead acid which dont have much of a shelf life to them. i have used the boxes a lot. take them camping for portable light options. i have a small 12 volt light (made it with a few tail light bulbs that i had left over from a 1987 Corolla) the box will keep it on all night and is VERY bright.
    my son was not quite used to the total darkness a rustic campground has, so the light was necessary for my piece of mind.
  18. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    wish Toyota would put in a battery saver feature on ALL interior lights
    I don't know if it's on the 3rd gen, but I really wish Toyota put on a feature that's common on Nissans (it's on my 04 350Z and was on my 02 Maxima). If you leave any of the interior or map lights on (even if the key isn't in the ignition), they automatically shut off after 30 minutes, to prevent draining the 12 volt.
    I believe it also works if you accidentally leave a door or trunk open, but IIRC, it doesn't work for the rear hatch of the Z.
    The above has saved me a bunch of times and I've sat in my Max w/the map light on and had it auto shut off on me at the 30 min mark.
    (I even posted about this when I was a Priuschat newbie at http://priuschat.com/forums/gen-ii-prius-main-forum/14548-new-06-prius-owner-bunch-questions.html and got a :rolleyes: response. :|)
  19. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    In the Lexus with AUTO-ON headlights, it's bad to leave them in AUTO-ON when storing for an extended period of time because the sensor apparently works all the time and this drains the battery, but the Prius doesn't have AUTO-ON.
    However, you haven't confirmed whether or not your friend's Prius has an alarm system, as it could be the culprit.
  20. tumbleweed
    4,067
    687
    Eastern Oregon
    I think kgall confirmed no alarm system in post #9 :).
