12 volt battery -24v ? (P0A80)
Discussion in 'Toyota Hybrids and EVs' started by blackhat, Jan 13, 2024.
  1. blackhat
    blackhat New Member
    71 Fenno St Norfolk County, US
    2012 toyota camry hybrid
    i was checking some of the readings on the torque pro app
    i couldnt figure out what the issue is
    some of the read out :
    Auxilary battery temp : -41.8F
    auxilary battery : -24.3v (Highest value22.5 lowest value 24.1)
    ambient temp :42F
    delta SOC :0.0
    hv chrg ctrl: -24kw (highest value: -3.5 lowest value: -24)
    coolant temp:132.8 (highest value: 141.8 lowest value -41.8)
    do i need a new 12v battery or maybe something else?
  2. Air_Boss
    Air_Boss Senior Member
    4,224
    1,188
    New Yawk
    Get a new reader.
  3. Mendel Leisk
    41,900
    Coolant temps are in Fahrenheit? Must be. Still, lowest value -41.8? And highest value oddly similar. Maybe baked-in range limits?
  4. Trollbait
    12,680
    Any actual symptoms of something wrong?
    Brian1954 likes this.
  5. Mendel Leisk
    41,900
    What does a multimeter voltage test of 12 volt battery say (first thing in morning, car off)?
  6. vvillovv
    vvillovv Senior Member
    4,329
    1,514
    NY
    I get some strange readings using Car Scanner -> All Sensors too and just ignore them util I know if they are too far off.
    I do get the exact same temp -41 F for the aux battery temp in Car Scanner. and it doesn't matter what time of year it is either.
  7. rjparker
    rjparker Tu Humilde Sirviente
    10,504
    6,593
    Texas Hill Country
    You must be setup for the wrong car or wrong units
    Car Scanner
  8. vvillovv
    4,329
    1,514
    NY
    Aux Battery Temp is at the Very bottom ( absolute last entry ) of Car Scanner -> All Sensors for my Gen 4 Prime.
    sorry if that was not clear in my post.
  9. blackhat
    blackhat New Member
    sometimes loses power or stalls its like losing fuel for a second
    and i already have the P0A80 and i remove the negative terminal for a couple of minutes and re-attach it, its goes back to normal
    i check the battery with headlights on with multimeter i got 12.19v
    i tried to upload png screenshot here but it doesnt work
