12 volt battery dead when parked 1 week
Discussion in 'Gen 2 Prius Main Forum' started by gdangelo, Feb 20, 2010.
  1. gdangelo
    gdangelo New Member
    My 12 volt battery is completely dead whenever I park my 2007 Prius for more than 5 or 6 days. I always make sure the smart key is turned off using the button underneath the steering column, but to no avail. I am told by my Toyota service rep that this is normal and expected! Does everyone experience the same problem? If so, isn't there a fix? At least there should be a device that enables easy disconnection of the battery, which is difficult to do and very inconvenient when you are running to catch a plane.
  2. iiwi
    iiwi Junior Member
    25
    Redwood City CA
    I've parked my 2006 Prius a few times for 3 weeks. It started up, no problem.
  3. blippo
    blippo New Member
    255
    VA
    I parked my 2009 for 3 weeks because of the snow. It didn't start up, so I charged it with my Battery Tender. Left it on for a day charging. After that it started right up.
  4. richard schumacher
    7,663
    1,038
    United States
  5. CarGuy60
    CarGuy60 New Member
    50
    Boston
    GD,You have a drain on your battery. Some small drain, such as a light in the glove compartment is staying energized. These things can be difficult to locate. If your under warranty bring it back to your dealer. If not under warranty find a good local garage specializing in auto wiring and lighting. Best of Luck
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    The fact is once a car battery goes dead it immed. starts to sulfate. Depending on how long it sat dead (sulfating) determines its future road worthiness or ability to just sit and keep a charge.
    My personal experience is once a car battery goes dead and needs a charge its done. Once it starts to sulfate it does not stop.
    Use that jump start to drive to dealer and buy a new battery or buy a yellowtop Optima which many posters seem to like as a replacement. Search.
    That battery will now get you everytime. And also exposes you the worst of achilles heels on this car. The foolish reverse polarity ooops I made a mistake jump start. That usually will total our cars. For that reason alone a suspect battery on my Prius is replaced.
    I will never jump start my car. So many posters on here reporting they correctly jumped there cars and now have $$$ thousands of dollars of damage.
    I have AAA and it gets towed home and a new battery installed. But really don't have to worry as I always beep the car even in the garage.
    Always.
    Then I shut the lights off in the garage and take 2 seconds and look at the car in the dark and make sure no lights are on inside the car. That hatch ajar will get you.
    And I have stored my car for 6 days with SKS on before and no problem started right up.
    Did you kill the battery before with a light and now it won't stay charged at the airport?
    They make battery disconnects but you'd have to go into the back well to the battery itself to get at it. A hassle at the airport but may be worth it to you.
    6 seconds of Google reveals:
    Here's a cheapie:
    http://www.amazon.com/HF-Tools-Battery-Terminal-Disconnect/dp/B001S0EIK4
    Here's real nice one:
    http://www.amazon.com/Moroso-74101-Heavy-Duty-Battery-Disconnect/dp/B000CON4MA
    BTW, always disconnect or switch the negative side of the battery.
    Good Luck!
  7. apriusfan
    apriusfan New Member
    6,050
    205
    S.F. Bay Area
    +1. Well, not 3 weeks; but certainly for 2 weeks at a time (business travel). The car has started right up with no long cranks. Maybe there is something wrong with the electrical system (as CarGuy posted in #5 above)?
  8. timberwolf
    timberwolf New Member
    220
    31
    UK
    There wouldn't be any long cranks because the power to crank the gasoline engine comes from the HV (traction) battery (201.6v nominal). When powering on the Prius, the little Aux 12v battery only has to start up the computers (ECUs) and switch a few relays to connect the HV battery.
  9. don_chuwish
    don_chuwish Well Seasoned Member
    816
    182
    Southern Oregon
    Wow, what a common thread theme. It gets rehashed over and over. Maybe someone (I nominate Richard!) should write up an authoritative 12V battery guide to become a sticky?
    - D
  10. richard schumacher
    7,663
    1,038
    United States
  11. avocadoman1
    avocadoman1 Member
    217
    36
    Fallbrook-CA
    2022 Prius
    i use to experience that problem, but no more...
    1) purchase an Optima Yellow Top (which i did)
    2) make sure that smart key is OFF
    3) make sure that the vehicle is in total OFF mode (no beeps with door open) and no lights on
    i just returned from an 8 day trip, my '06 started right up.
  12. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Nope. Not normal. I've never had my 12V battery die once in my 4 years of ownership yet.
    Last year, I left the country for an 11 day trip w/my Prius parked (nobody else drives/shares my car) and the battery was fine when I returned. I'm pretty sure I disabled SKS. Within a month, I took advantage of the one week test drive of a Lexus HS 250h so my Prius was sat not driven for a week w/o issue.
  13. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    You won't get "long cranks" a Prius due to a low 12V battery. The ICE in the Prius isn't and can't be started by the 12V, unlike on conventional cars. It's started by the big HV battery.
    The Prius also has no separate starter motor.
  14. don_chuwish
    816
    182
    Southern Oregon
    Nice, sure that could work. Maybe it just needs to be in several forums.
    - D
  15. don_chuwish
    816
    182
    Southern Oregon
  16. ski.dive
    ski.dive Active Member
    893
    230
    Hutchinson Island,FL. Mt. Snow,VT
    I went to Costa Rica for 3 months, and my PRIUS started right up.
    No battery problems here!!!!
  17. Patrick Wong
    18,200
    6,472
    The Prius 12V battery is like the Prius fuel tank in the following ways:
    The maximum capacity of each is variable. In the case of the battery, the capacity depends on age and the extent to which the battery has deteriorated as it remains discharged for a prolonged period of time due to lack of driving time or leaving a cabin light on. In the case of the fuel tank, the bladder.
    The available amount of Ah (in the case of the battery) or gallons (in the case of the fuel tank) can only be guessed. In the case of the battery, if the car is used only occasionally and for short trips, the battery may well be operating at only 25% - 50% charge over an extended period. The accuracy of the Prius fuel gauge has been commented on repeatedly, no need to rehash here.
    Hence, no surprise that there is a wide range of experience regarding leaving the Prius for one or two weeks and then coming back to find the battery either dead or else willing to make your car READY.
