12 volt battery drain
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Tom Obenschain, Oct 16, 2021.
  1. Tom Obenschain
    Tom Obenschain Junior Member
    2020 Prius
    L Eco
    i am thinking of replacing my 2020 L Eco with a 2022 Limited. I wonder if this will result in more battery drain due to more sensors. Smart key sensor is only on the driver's door for L Eco. Limited has three times the sensors. i do not drive often. Thus there is more battery drain. This was a problem on my C which also had three sensors.
  2. BellevilleMXZ
    BellevilleMXZ Member
    72
    61
    Ontario,Canada
    2024 Prius
    Limited AWD-e
    I would think it would be a very very slight difference
  3. CooCooCaChoo
    CooCooCaChoo Senior Member
    961
    542
    Cow-lee-fornia
    2023 Prius
    May not be a BHG. The cooling also runs to the exhaust pipes. That part of the system has been known to leak and become defective.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    You are taking the wrong approach here.
    THIS is what you need to address, no matter what make or model car you have.
    The common solution is a battery tender.
    Note: If you don't have the C anymore you might want to change that in your profile.
  5. bisco
    52,395
    can you turn off sks? it might even turn itself off after a time
  6. vvillovv
    vvillovv Senior Member
    4,332
    1,515
    NY
    If I understand your concerns correctly from how I read your post, I wouldn't worry about it, to much anyways.
    I haven't seen any reports here at PC about gen 4 (any trim / model) having 12 volt issues, yet.
    like they say YMMV ;)
