12 Volt battery for 2012 Prius -maintenance free?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tommy T., Apr 20, 2017.
  1. Tommy T.
    Tommy T. Junior Member
    Willcox, AZ
    Is the 12 Volt battery for 2012 Prius maintenance free?
  2. AzWxGuy
    AzWxGuy Weather Guy
    979
    495
    Tucson, AZ
    2021 Prius
    To my knowledge, Gen II and III 12V auxiliary batteries are sealed and externally vented. Read some Gen II posts about guys prying up the seals and adding distilled water, but with an AGM (absorbed glass mat) battery how would you know how much water to add. Yes, maintenance free for 5-6 years (assuming you don't deep discharge it) and then replaced.
    49,386
  4. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    No. The battery really needs to have water added after a few years. BUT it's "maintenance impossible". You can't add water as it's sealed.
    You -can- check the terminals/connections for oxidation and to ensure they are tight.
    I was one of those guys Arwxguy mentioned. On the GII battery. The GIII battery is glued together so I didn't bother. I just replaced it.
  5. Mendel Leisk
    38,651
    The 4th gen battery looks to be conventional, larger, regular post size, back in the engine bay, with accessible caps and translucent sidewalls with level markings.
  6. bisco
    49,386
    mine is now 5 years old. no idea where the water level is, but it is still very strong, the posts require no cleaning or tightening, and i expect it to last 10 years, maintenance free.
    but i have never abused it in any way, other than letting it sit every winter for 5 weeks with sks on.
