12 volt battery life
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by austingreen, Dec 5, 2011.
  1. austingreen
    austingreen Senior Member
    13,563
    4,101
    Austin, TX, USA
    I ended up having to jump start my car last night. It is now 24 months old. It started fine twice today. I was wondering what might have made it not work its not like it could be a bad alternator or I left the lights on (I did but they shut off automatically. Might the battery be bad already?
  2. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    I'm not an electrical expert but in my experience 24 months is within the range for auto batteries to lose functionionality these days.
    If you can, do a voltage test before you fire up in the morning.
    From what I've read on this forum you should have in excess of 11.7 volts. If not then likely your battery is dying or there is an electrical malfunction some where.
    I'm sure someone with more knowledge will also advise. :)
  3. Mendel Leisk
    38,635
    If you can get a hold of a half-decent multimeter: check the voltage at the jumpstart terminal and a ground. A healthy battery will read 12.6 volts or higher. Anything around 12.5 or lower is iffy. You might be able to revive it with a charger.
  4. austingreen
    13,563
    4,101
    Austin, TX, USA
    moderators, this was meant to be in the Gen III section
    Thanks. It started fine yesterday and today, but its reading 12.5v. The hybrid Battery was down to II bars when I jumped it if that means anything, and I let it automatically turn off my lights Friday night. It may be close to the end of its life though. I think the battery has a 3 year warranty, but may want an optima instead.
  5. derkraut
    derkraut Member
    299
    27
    SAN
    Your battery should certainly last longer than 2yrs. The 12V battery in my 2006 lasted 5+yrs, with no problem whatsoever, until it suddenly died. A reading of 12.5V is within normal limits for a good battery. If you go for long periods (say-more than a week) without driving, I would manually turn off the headlights, and disable the smart key sensor (button under the dash, next to the tps button near the steering column)
  6. Eoin
    Eoin Active Member
    593
    116
    Long Island
    My original 2005 battery is just fine.
  7. volcomholls
    volcomholls Junior Member
    28
    Wilmington, NC
    2024 Prius
    My 2008 was just replaced last week. Took it to the dealer for the CEL light and they said it needed to be replaced. No problems starting recently; only had an issue in the dead of winter last year - had the windshield replaced/doors open for several hours in 20 degree weather and it died. No problems after jump start. No CEL light then either. The dealer hounded me for replacing it, but suspected they were just trying to sell a battery.
    After it was replaced last week, 40 miles later the CEL light is back on. So I guess it wasn't the battery after all, but I'm still not so happy with the dealer and the diagnosis.
  8. austingreen
    13,563
    4,101
    Austin, TX, USA
    That's what I thought. I will be manually turning off the lights from now on. I have a Gen III, so I don't have a button to turn off smart key. The car was only parked for 5 hours, but I had been doing short trips saturday, which I would blame if it was a regular ice car. Mileage has been bad since the jump start, but hybrid battery was low then and is full now, so I don't know if the extra gas is just charging the batteries.
  9. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    12.5v is fine. mine sits at about 12.4v and i have no problems and my gas mileage is normal. i have had this Optima for few years now.
  10. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    a prius 12v battery should last 4 to 6 years (with smart key)
    if the battery has to be jumped.. it has to be replaced... there really is no recovering these batteries from a dead state.. they just kinda keep staying dead (stops holding the charge it once did)
    (just my opinion from experience.. and watching these forums) i always tell people to either have the car off... or in READY.... nothing else since these batteries are not very big.
  11. Mike James
    Mike James Camaros and Prii go figure
    142
    35
    Lincoln, NE
    I agree, it is in the chemistry of the lead acid battery. Running a lead acid battery low just nocks the life out of them.
  12. CPSDarren
    CPSDarren CPS Technician
    533
    112
    Chicago
    Like all things, battery lifetime varies with quality. It will also depend not only upon age, but more importantly, the number of temperature ahd charge cycles the battery encounters.
    Two years may be on the low end, but I bet it is within the normal range of failure rates for a typical driver, especially if you are in a warmer climate where batteries tend to have lower lifetime.
  13. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    It,s actually a AGM battery for various safety reasons. The battery is only about 35 Amperes and the charging system is anemic, compared to other cars and trucks. I think Toyota design engineers had to make a sacrafice somewhere to maintain the HV at its highest charge and the 12V was it. The 12V cannot take having the radio and lights on for 5 hours in Aux mode. Always have it in ready, so the 12V at least maintains its charge.:rockon:
  14. Flying White Dutchman
    4,374
    313
    i kust replaced mine! 3,75 years old
    did not drive a lot and car always at charger 12 volt when parked at home.
    so i think that a bad periode... way to short
    but now i have a new battery and a new smart trickle charger... lets see over 3-4 years!;-)
  15. kscheuer
    kscheuer Junior Member
    My Prius is a 2005. I had not ever checked the battery because it was not listed in the maintenance schedule. I changed the oil and air filter and next day all the lights on the display were blinking. I thought maybe some particulates got in the sensor under the air filter, cleaned it out and no change. I called the dealer who said have it towed in (it's 22 miles to the dealer). I asked if there was anything else I could try. He said disconnect the battery to see if it would clear the codes. I did, but afterwards all was blank. So it cost $220 for the tow, $186 for a new battery, and another $200 for diagnostics and labor. All that was wrong was that it had a dead battery. I have a charger at home. The take away is $600 is too much for a dead battery. It should have been listed in the maintenance schedule and I should have tried to charge it myself. It would have saved a lot of grief. The dealers said they should last 3 years, but to check it every year so you won't get a big surprise. That was my 2nd long distance tow for electronic problems. I have since joined AAA.
  16. snead_c
    snead_c Jam Ma's Car
    667
    58
    Hendersonville
    If you ever need a jump be sure the AAA tow service knows how to jump a Prius...better still learn how yourself and "supervise" . When you have the hood up locate the recommended jump points. Perhaps even mark them with colored tape...one is already red.;)
  17. frigleycat
    frigleycat New Member
    pennsylvania
    My service advisor early on told me to keep the key away from the car at least 15'. As all of the remote entry keys are, it is an addressable key and will drain the battery if left in the car or in close proximity to it. I am replacing my battery today and I have a 2007 1/2 prius that is 4 yrs and 7 months old. I thought it should go 5 years plus, but I think the cold weather has hastened its demise. Still, at the cost to replace this 12 volt battery, thought it should have a longer life.
  18. dispatcher
    dispatcher Junior Member
    Justin, tx
    how do u like the new wagon?
  19. dispatcher
    Justin, tx
    is the Optima battery + kit at $170 the best way to go for a replacement?
    my 2007 has 103,00 and I figure it is time to replace it before any problems.
  20. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    My unsupported position is that because the battery is in the passenger compartment, Toyota engineers leaned on the side of safety. Overcharging can cause Hydrogen gas or Sulfuric vapors to be released. That would be bad.
