12 volt battery possibly leaking water?
Discussion in 'Gen 2 Prius Main Forum' started by GeorgeMW, Aug 8, 2018.
  1. GeorgeMW
    GeorgeMW Junior Member
    56
    Georgia
    hello guys! i have an '06 prius and it seems to be leaking water (or a liquid similar to it) below the 12 volt battery...
    is this normal?
    #1 GeorgeMW, Aug 8, 2018
  2. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    Is the liquid leaving a residue?
    How many miles on your Prius?
    Original hv battery?
    Ever opened the pack?
    Any dash lights?
    It could be the electrolyte fluid out of a module. But more information will be needed;).
    Good luck and keep us posted (y).
  3. GeorgeMW
    56
    Georgia
    ah! my bad! its the 12 volt battery, not the hybrid one, sorry.
    Raytheeagle likes this.
  4. GeorgeMW
    56
    Georgia
    also, this liquid may be piling up from somewhere else, and i think it is because of rain or something...
    its about 500grams
  5. ITBland
    ITBland Active Member
    433
    272
    New Orleans, La area, US
    Do a search for hatch leaks--the "caulk" in the seams under the hatch (in the water run-off channels around the hatch opening) sometimes develop cracks letting rain water in--it needs to be sealed to prevent potential problems with the HV battery!
    Edit: Here is one: Water leak...into spare tire area etc
    Raytheeagle, jerrymildred and bisco like this.
  6. bisco
    49,371
    also the rain gutters.
    ITBland likes this.
  7. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    I agree that rain leakage is more likely than battery leakage. Since you need to remove the battery anyway to dry out the battery well, I would dry the battery thoroughly and set it on a bench on a paper towel. Check the paper towel after you finish cleaning up the mess in the car and you'll know. Also, if you're not wearing rubber gloves when cleaning up the liquid in the battery well, you will find out then if it's from the battery. ;)
    ITBland likes this.
