12 volt battery ?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by myself1, Sep 2, 2013.
  1. myself1
    myself1 New Member
    yes,my 1st post hopefully I don't sound knowledgeable in regards to my 2010 model 2.I was just wondering if the 12 volt dies on me,since i back into garage how 'ld I be able to get the car out of park i'ld not to be able to open hatch back.i'am sure this probably a easy to you guys.THANK YOU
  2. rdgrimes
    rdgrimes Senior Member
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    You can jump the car from under the hood, following the instructions in the manual. You only need to get the system started then you can pull out to access the battery. Or, just replace the battery now to avoid trouble.
  3. vskid3
    vskid3 Active Member
    773
    228
    You'll likely have some warning signs before the battery dies enough to not start the car. If you're really worried about it, I would check the battery voltage after the car has been sitting for several hours every month or two.
  4. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    When the 12V battery finally does die, access to the power "boost point" is under the hood, so you're good. It's more difficult to get to the battery as the hatch release is electric. There is a manual hatch release but you have to crawl over the back seat and lift the hatch floor to get at it.
  5. The Transporter
    Sunny Surrey BC
    Use a battery maintainer while parking in the garage. I have a genius 3500, very easy to install and use it.
  6. phoenixgreg
    phoenixgreg Senior member
    1,157
    289
    66
    Phoenix
    Someone here posted a neat tip on how to tell if the 12 volt battery is dying. Put the car in accessory mode after it's been sitting overnight and try the driver's power window. Does it seem sluggish or slower than when the car is in Ready mode? Time to replace the battery.
  7. szgabor
    szgabor Active Member
    993
    175
    Oceanside NY
    This is only sound tip IF the car had been running (being in Ready) for well over an hour before that over night sitting. A fairly discharge 12 V prius battery takes quite a long time to be fully charged (due to a very low charging current ). Just a few short trip can quite a bit discharge the battery.
    Of course the battery could be charged with an appropriate battery charger as well again max 4 A is recommended el-chepo conventional (older) charger can damage the battery. And then this test maybe usefull.
