12 volt battery.
Discussion in 'Gen 3 Prius Technical Discussion' started by GoMetricToday, Mar 24, 2011.
  1. GoMetricToday
    GoMetricToday 42 is the answer to the ultimate question.
    64
    Erwin, TN
    Ok for the life of me I can't figure out where the 12 volt battery is in my 2010 Prius. I read discussions on here about the 12 volt battery. I have looked every where I possibly can to find it in my car and can't seem to locate it. It isn't under the hood, nor can I find it in the boot near the traction battery. Am I over looking something?
    Go ahead and laugh and have a good guffaw at my expense. LOL. Hell even I had a bit of a chortle.
    So anyone? Can you tell me? :D
    49,358
    should be in your owners manual. not the battery, the location. it's in the right rear fender, there is a little flap in the triangular area of the floor.
  3. 32cayuga
    32cayuga Junior Member
    Newton, IA
    The small 12 Volt battery is located under the rear cargo panel behind the rear wheel on the passenger side of the car. Good hunting, enjoy your Prius.
    Dave
  4. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    ImageUploadedByTapatalk1300995182.012589.jpg Here it is. This is taken from the left looking to the right. Remove your folding storage area cover, then remove the storage tray. Next take out the small cover panel in the right corner. Then you should see it.
  5. GoMetricToday
    64
    Erwin, TN
    Brilliant!!! Thank you very much everyone.
  6. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Look on the bright side, it is clearly not in the way, there.
  7. Metalman
    Metalman Member
    107
    17
    Summer, KY; Winter FL
    Coincidentally, I looked at the battery for the first time today. It's not any bigger (volume) than the battery on my Sportster. No doubt it will be expensive to replace, since it doesn't look like a standard automotive battery.
  8. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
  9. mpriusownr
    mpriusownr New Member
    Central Texas
    Is this possible to answer, how long does a typical 12v battery last?
  10. stereos
    stereos Junior Member
    Idaho Falls
    Most batteries last 3-10 years. It should be tested so it isn't weak and make your charging system work harder than normal.
  11. Den49
    Den49 Member
    498
    268
    Maryland
