12 volt outlet
Discussion in 'Gen 2 Prius Accessories & Modifications' started by agile pagile, Mar 18, 2005.
  1. agile pagile
    agile pagile New Member
    46
    Benicia, Ca
    What sort of converter can I plug into either 12 volt outlet. What types of equipment can I then use. I hope my question is clear. I guess I need to know how powerful of a converter I will need. I have a 2005 Seaside #6 that I lucked out on and bought the day that I saw it. Thanks very much, Pagile
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Seems like you're asking the question backwards to me. What is it you want to plug into a 12v AC converter? Laptop? DVD player?
    Just about any commercial converter with a 12v adapter should work fine. Most of the time they tell you how much 'juice' you get on the box and what kind of equiptment that much 'juice' will power.
  3. mspencer
    mspencer New Member
    101
    Council Bluffs, Iowa
    I think his question is more, what's the current capacity of those 12V outlets? How much amperage can you draw before you're in danger of blowing a fuse? What car subsystems share the same circuit?
    He probably already knows you need an inverter rated for at least the VA rating of the equipment you're powering -- but if I plug a big honkin 750 watt inverter into the 12 volt outlet, then plug a 500 watt halogen work light into that and hit the switch, will a fuse pop?
    (Not trying to put words in anyones' mouth here...sorry if I've misunderstood the original poster...)
    --Spence
  4. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    The outlets have 15A dedicated fuses, but are rated for 120W or 10A. Toyota puts a margin of error/safety between max draw and fuse rating.
