12 vt battery - is the dealer right??!!
Discussion in 'Gen 2 Prius Main Forum' started by Bernie Ferrone, Sep 10, 2010.
  1. Bernie Ferrone
    Bernie Ferrone Junior Member
    28
    Greenville, SC
    Since my 2007 battery is almost 4 yrs old, I decided to do some testing of my 12 vt battery with a good volt meter on the connection in the fuse box under the hood. After numerous readings, the average was 12.5 after driving/sitting some and dropped to 11.5 when turning on the car without the motor being on. The lower reading under load concerned me, so off to the dealer I went. The dealer told me it was fine and the lower reading would have to get below 9.5 to indicate a problem. Do you all agree with the dealer? Thanks.
    51,154
    i agree with the dealer. if it ain't barroque, don't fix it!:D my daughters 04 is still on the original battree.
  3. krg03
    krg03 Not expert, just experienced
    246
    31
    so cal
    Use the car diagnostic mode to test.
  4. Patrick Wong
    18,200
    6,493
    No, I do not agree.
    First of all, when you are doing your battery voltage measurements, you should do this after the car has rested overnight. This will dissipate the surface charge that exists after the battery has been charged while the car has been READY.
    A fully-charged AGM battery in new condition will measure 12.9V when the car is IG-OFF. If you measure 12.2V or lower then I would replace it.
    11.5V under IG-ON condition is the lowest that I would accept. If the voltage was 9.5V when the car is IG-ON, then it is quite likely that the car either would not start or else would exhibit glitchy behavior, of which we have seen numerous posts.
    I would prefer to err on the side of replacing the battery in advance of a failure. Other owners prefer to wait for the battery to fail before taking action. If you enjoy that sort of drama (and don't object to the increased cost of performing repair under emergency conditions), then peace.
    2 people like this.
  5. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
  6. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Hi Bernie. Whether or not the 11.5 volt reading indicates a problem depends a lot on how long that reading lasted. The 12V battery must supply a brief surge of current when the car is first started, so if this 11.5 volt reading was just for one second or so then I wouldn't worry about it.
    Try taking the following three measurements (preferably at least several hours after driving the car).
    1.Voltage when car is fully off (this is the open circuit voltage).
    2. Voltage when placed in accessory mode (hit power on without foot on brake).
    3. Voltage in accessory mode with headlights on (just normal low beam). This one will probably drift downward a little bit while you're watching it, take a reading after about 10 to 20 seconds.
  7. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    Frankly, I surprised that your dealer said that everything would be fine
    down to 9.5V.
    That's a far cry from what the majority of bad battery stories posted
    here report. 10.5V is the lowest reported reading I've seen where
    the car operated, but erratically at that. Typical low battery problems
    include: the car won't start, the car won't turn off, significantly reduced
    MPG's, and a very dramatic display of warning lights on the dash.
    What with colder temps coming on, the battery readings after an
    overnight cold-soak -- that's when they should be taken -- will be even
    lower.
    It seems like now is the time to get that new battery.
    Hmm... maybe your dealer runs a towing service as well. :rolleyes:
    If it comes to this, tell him to send his flat bed truck.
  8. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Your daughter's battery is living on borrowed time. She should replace it.
  9. jreed
    jreed Member
    84
    71
    North Carolina
    I replaced the 12V battery on my '06 at ~98K miles with the elearn aid deal. The original battery (Denso) was reading 11.9V at rest. I didn't want to risk having to jump start the car which I've read has inadvertently damaged the inverters of some posters.
  10. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    Good post. This is the first car where i will be replacing the 12v sonner rather than later. Because of the many reasons i have read in posts, such as giving false error/ lower mpg ect.
  11. Bob.H
    Bob.H Junior Member
    38
    Findlay, Ohio
    I look at that 12 Volt Battery like any other preventative maintenance item. If it dies unexpectedly you will loose a day or more getting it fixed when you need your car for something important. Let alone the cost or damage done to it getting towed to the shop and paying whatever they say just to get it back.
    Shop around now or DIY on your own planned schedule.
    Bob
  12. Patrick Wong
    18,200
    6,493
    So true.
    A work associate also owns a 2G. He is a competent DIYer and certainly could replace the 12V battery himself.
    A few months ago, he told me he spent $400 last winter to replace the 12V battery. I replied, how could you possibly spend so much?
    The good news was that he owns four cars so he has plenty of alternate transportation. The bad news was that his Prius, the daily driver, was parked in such a way so that he could not get any of the other cars out of the garage. Since this was a work day, he was in a rush, so he paid for a tow truck ($100) to tow the Prius to the dealer.
    Then the dealer tech diagnosed ($100) that the problem was the 12V battery. The dealer then charged $200 for the battery and installation.
    If he had planned the 12V battery change in advance he might have paid $139 MSRP for the replacement battery and enjoyed a 30 minute project. But no. Instead he paid $400 for unneeded drama.
    Each winter, I've noticed a few forum stories that have followed a similar story line.
  13. bisco
    51,154
    i wonder how long a battery can last?
  14. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
    Wow what a story! Was the 12V battery so dead that it couldn't even be jumped? Stories like this would be a good motivation for the Prius owners to at least check the battery voltage frequently even if they want to maximize the battery service time thus opt not to change it on a fixed schedule.
  15. richard schumacher
    7,664
    1,043
    United States
  16. Patrick Wong
    18,200
    6,493
    At the time this happened, it was not clear to my work associate that the 12V battery was the problem, given the stress inherent in the situation where the car was not behaving as expected.
    Of course, should this happen to any of us and we didn't have a digital multimeter available, we would think about looking at the interior cabin lights to assess their brightness which provides a clue to the 12V battery voltage level. We also would probably turn on the headlights (briefly) to see how bright they are, thus testing the battery's ability to provide power under a moderate load.
    I'm sure that there are some Classic owners who still have the original equipment 12V battery installed. However, the capacity of said battery will be quite low and in the event of an emergency it is doubtful that battery will have much reserve to draw upon. Also, if the owner doesn't pay attention to clues manifested by cabin light brightness etc., then one day that owner will be stuck in a parking lot when the car won't start on a cold winter night.
  17. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    The dealers a goof ball and doesn't know the first thing about batteries. For total peace of mind, heed Pat's advice. :D
  18. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    Depends on who you talk to, the car, the type of battery, the climate.
    I had a 1987 Nissan Sentra (bare bones model - but got up to 40 mpg on the highway!) that started acting flaky in 1994 or '95. Occasionally it wouldn't start but I would wiggle the battery connections a little and then it'd be okay. But one time this happened when I was on a ferry crossing the Potomac, and they were getting the farm tractor out to pull me off the ferry before I got it started (the other cars were waiting for the return trip, and I was the only car still on the ferry). That's when I decided to replace the battery, which was probably about 8 years old by that point.
    My current battery is 3.5 years old, maybe I should check it before winter. Usually they last 5 - 6 years in my experience though. The Prius has a little different 12V battery than most.
  19. fuzzy1
    10,335
    How long can a battery last? A very long time. I usually let my household's nonhybrids go to near failure. One went 9 years, typical is about 7.
    How long will a battery last? Far less for average drivers, most of whom live with battery-damaging hotter summers, colder winters, or both. Drivers who must have a specific car running on any specific day, and cannot simply hop into a spare vehicle until they have time to replace their own battery, will usually find that this sort of brinksmanship will cost more money than it saves.
  20. dhancock
    dhancock 2 Prius Family
    357
    40
    Hamburg, NY (Buffalo area)
    I note elsewhere that when Patrick replaces the 12v battery he uses the OEM battery and not the Optima. I keep wondering why.
