120k mile checkup -quoted $1300+
Discussion in 'Gen 3 Prius Technical Discussion' started by JadeKW, Dec 17, 2024.
  1. JadeKW
    JadeKW New Member
    Connecticut
    Just brought my 2013 Prius in for an oil change and I’m being told it’s overdue for almost $1300 in service for its 100k and 120k mile checkups. I agreed to the oil change and tire rotation ($105.15) and declined the spark plugs ($296.62), PCV Valve ($515.83), and transmission flush ($447). I’ve had this car for over seven years and I have no plans on replacing it anytime soon. I kept my (first) last car until it died after 350k miles (an Acura Integra). Any and all advice would be greatly appreciated!
  2. PriusCamper
    PriusCamper Senior Member
    11,981
    4,870
    Pacific Northwest, USA
    What a bunch of criminals! I charge $120 for spark plugs, throttle body and MAF sensor cleaning including parts. Transmisison flush is less than a hundred dollars (only needs to be done once over vehicle lifespan) and PCV valve is good for life of car unless you're having a diagnosis challenge and want to eliminate that concern. I'd charge just under $150 for PCV valve. Evidently, owner of shop you went to is behind on their mortgage or something.
    bobby515 and ForestBeekeeper like this.
  3. jdenenberg
    jdenenberg EE Professor
    3,918
    1,917
    Trumbull, CT
    2020 Prius
    LE AWD-e
    A Prius does not have a torque converter so you never need to do a "Flush". Only do a drain and refill of the correct ATF which runs just a bit over $100 at my Toyota dealer. It is worth doing one at 30k miles and every 60-90k thereafter.
    JeffD
  4. ASRDogman
    ASRDogman Senior Member
    7,116
    3,713
    You wasted your money on the tire rotation....
    But, you are due for spark plugs. PCV valve, maybe.
    Toyota service book says the transmission fluid is lifetime, so it never needs changing.
    But, "lifetime" means for the life of the car and emission warranty.
    It is best to change it at 100,000 miles or so. Then 50,000 miles after that.
    ALL of these things you can do yourself. Unless you have no mechanical ability.
    It only takes a few basic tools, all costs would be recouped by not paying someone
    to do it for you.
    There is no filter for the transmission. You just drain it and fill it.
    Don't forget that the engine coolant and the inverter coolant needs to be changed.
    Both, drain and refill. Funny they didn't mention that....
    If you can't do the work, then it would be better to find an independent shop that knows about
    the Prius.
    #4 ASRDogman, Dec 17, 2024
  5. JC91006
    16,656
    8,504
    A PCV valve replacement for $515.00 I think that's a record for a $15 part and less than 1 hour of work
    Grit and Brian1954 like this.
  6. BiomedO1
    BiomedO1 Senior Member
    2,725
    1,456
    SacTown, Ca
    Your spark plugs should be replaced and the transmission fluid should be changed, if it hasn't been in the past. That said, any qualified 3nd party repair shop can perform the job for 1/3 the price you were quoted. No special tools or scanners required. The transmission fluid change is a simple drain & fill - No flush needed.
    The PCV valve doesn't need replacement, unless it's throwing codes pointing to it being defective. The EGR pathways gets clogged with carbon, so replacing that valve with a clogged EGR kinda defeats the purpose. The entire assembly needs to be removed and 'hot tanked' to remove all the carbon within. Specialty Prius shops can do this job, because it's a well know issue.
    Hope this helps....
  7. PriusCamper
    11,981
    4,870
    PriusChatters back about 15 years ago studied this and did lab analysis of everyone's Transmission fluid and the data indicated there was a benefit in changing out the original fluid which had initial wear materials in it from when everything in the transmisison was brand new and it would be beneficial to change it out at least once. But changing it out more than once showed very little material / benefits, which is why Toyota used to say that ATF was good for the life of the vehicle.
  8. Grit
    Grit Senior Member
    6,413
    4,181
    Wilkes Land
    Spark plugs are due at 120,000mi, right under $300 is average price. Get that done, engine knocks will come knockin. Trans flush is not required for Prius, drain refill only but get that done. Their price is waaay steep for that, $150 - $200 is reasonable price. Mine has 240,000 mi so like you, this car is gonna be driven to the ground.
  9. JC91006
    16,656
    8,504
    The transmission fluid isn't a big deal as they classify that as a "lifetime fluid". I would however change it out say every 60-80k miles, just so you have some fresh fluid. This fluid doesn't get contaminated with fuel like your engine oil. So it's not urgent to get changed but it's good to keep it fresh every 60-80k miles or so.
  10. Leadfoot J. McCoalroller
    7,828
    7,294
    Pennsylvania
    2018 Prius c
    If you keep going back to the dealer and asking for service based on your odometer reading, they're going to rake you over the coals.
    It's not necessarily bad for the car, but it'll be very expensive.
    If you learn what services your car needs and ask for them by name, things will feel more affordable.
    If you give the business to an independent mechanic instead of the dealer, it's likely to get a lot more affordable for the same results.
    PriusCamper likes this.
  11. Mendel Leisk
    40,467
    According to Toyota USA (and going from memory…), 120k miles is:
    oil and filter change
    Wheel rotation
    In-depth brake inspection
    Spark plug replacement
    that’s it. There’s also drivers floor mat check, and a multitude of other nonsense that doesn’t need doing (and isn’t done).
    the $447 “transmission flush” takes the cake lol.
  12. PriusCamper
    11,981
    4,870
    I think throttle body, MAF sensor cleaning and new engine air filter are on that list too.
  13. Mendel Leisk
    40,467
    Nothing about throttle body or MAF sensor cleaning, but yes, both cabin and engine filters to be replaced. FWIW, I would only change those if warranted, and wouldn't pay dealership labour rates to have them do it.
  14. CHOUST
    CHOUST New Member
    Long Beach, CA
    Hi I need to replace the big battery on a 2007 prius. I am in Long Beach CA Can you help me find a $600 or less battery to install today??? I was trying to send a message to JC 91006
  15. ASRDogman
    7,116
    3,713
    Answered here: New Prius owner | PriusChat
    No need to post the same question in multiple threads.
