125k....Going for maintenance...Anything else?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by G Man v5, Nov 10, 2016.
  1. G Man v5
    G Man v5 Member
    158
    Well, I'm around 125K.
    Thinking of the following:
    ATF change
    Both Coolant Changes
    Transaxle fluid change. (what fluid is rec?)
    Any other fluids?
    Thanks.
    52,393
    brake fluid? not sure if it's on toyota's schedule, but might be a good idea.
    atf and transaxle would be the same. use toyota brand only.
  3. Mendel Leisk
    41,906
    Specifically: Toyota ATF WS. From page 503 of the 2012 Prius v lowercase v for the Prius v wagon Owner's Manual:
    I'd second the brake fluid change, Toyota Canada's now saying every 3 years or 48,000 kms. It attracts water, which is bad in a lot of ways for the brake hydraulics.
    Both coolant circuits is probably a good idea, doesn't hurt. Only thing, if it's the same as the reg Prius, the inverter circuit is 150,000 miles or 180 months. FWIW, the Canadian schedule makes no distinction, both at the engine circuit interval. This is a cheat sheet I did of the US schedule, again, it's for 2010 reg Prius:
    #3 Mendel Leisk, Nov 10, 2016
    lvidmar, G Man v5 and bisco like this.
  4. G Man v5
    G Man v5 Member
    158
    Thank you Mendel.
