12oz Super Tech R-134A Freon OK for Prius A/C ???
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Jul 8, 2019.
  1. ski.dive
    ski.dive Active Member
    896
    231
    Hutchinson Island,FL. Mt. Snow,VT
    Description on back of freon can says;
    Contains 12oz of R-134A
    ***This can of R134A seems to NOT have oil?
    #1 ski.dive, Jul 8, 2019
  2. Stimp
    Stimp Member
    53
    North Carolina
    LMGTFY
    Let me Google that for you
    Skibob likes this.
  3. oldtechaa
    oldtechaa Active Member
    336
    222
    NZ
    2013 Prius Alpha
    That didn't really answer the question. The question was whether Super Tech refrigerant has oil or not, which is a concern because the Prius cannot use PAG oil but must use ND-11 or be recharged with an oil-free refrigerant can.
  4. Stimp
    Stimp Member
    53
    North Carolina
    The post is edited, and still doesn't ask if it has oil. The original question is what LMGTFY addresses, literally copied and pasted from his post.
  5. Leadfoot J. McCoalroller
    7,176
    6,722
    Pennsylvania
    2018 Prius c
    I noticed the edit too.
    @ski.dive I agree with your reading of the label- sure looks like there's no oil in that product.
  6. ski.dive
    896
    231
    I just got back from WalMart
    is available at WALMART for $4.88
    ***It is R-134A Freon and it contains NO OIL or other additives=Should be OK for Prius.
  7. John321
    John321 Senior Member
    1,210
    1,209
    Kentucky
    If it is any help to you here is the setup I used to add a little Freon to our 2008 Prius when we had it (see the picture below) . I believe it is the same stuff you are asking about. It didn't take much to fill it as the system was in good shape I just topped it off. If your cabin filter is dirty it will make a big difference in air flow when you replace or clean it!
  8. Leadfoot J. McCoalroller
    7,176
    6,722
    Pennsylvania
    2018 Prius c
    Many late model import cars are super touchy about refrigerant levels. A little under and you only get half the cooling. A little over and the compressor blows up.
  9. John321
    1,210
    1,209
    Kentucky
    Wonderful point about pressures. Just adding refrigerant because you think more will make it cooler is a recipe for disaster. Here is a page from the Prius service manual on what your pressures should be reading
  10. ski.dive
    896
    231
    ***JOHN321 = Where did you buy the can adapter with the built in gauge and hose?
  11. John321
    1,210
    1,209
    Kentucky
    ski.drive I bought it at Walmart also. Our local Walmart had a nice selection. It is made by idQ and cost around $15. The gauge accuracy was comparable to a manifold gauge set and reads from 0 psi to 150 psi. It has red and green zones to help gauge the health of your system. The green section also has a calibration gauge for outside temperature to help you gauge the actual correct pressure of your system.
  12. ski.dive
    896
    231
    [​IMG] The only ingredient is R-134a... At only $4.88 for a12oz can, it's a great buy at WalMart for our Prius.
