12v almost dead. What replacement fits?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Hawaii Magic, Aug 13, 2018.
  1. Hawaii Magic
    Hawaii Magic New Member
    Hilo, Hawaii
    2014 Prius c
    my 2014 c battery is so dead that soon jump starting won’t start it. it needs replacement.
  2. PriusCamper
    PriusCamper Senior Member
    11,059
    4,502
    Pacific Northwest, USA
    The auto parts stores sell over-priced batteries for Prius... Main reason being Prius 12 volts are not normal 12 volt car batteries in that they don't power a starter motor because the Hybrid battery pack does that, so you don't need much from a 12 volt battery, which means lots of rip-off sellers like Optima Yellow Top and others are scamming people simply because Prius is different.
    Batteries Plus most common AGM 12 volt battery that they sell at $130 for wheelchairs and back up computer power supplies are the best because they sell so many of them that there's never an issue of them sitting on a shelf for too long. They also have way more amp-hours then the $230 ones the auto parts store recommend. Only issue is that terminal mounting hardward is slightly different so you'll need some longer bolts and bushings from your local hardware store.
    49,384
    try auto parts, internet, dealer. not sure what you can get in hawaii.
  4. cutter44
    cutter44 Member
    213
    MA
    Speaking of the 12V battery, how am I going to know when it's on its last legs? With a conventional car, you can tell because it struggles and takes longer to crank. It seems that with the Prius it's fine...until it isn't? Will it give me a clue when it's time or will I just not be able to start the car? I have a 2012 with 110k miles. Not sure if this is the original battery (I bought the car with 34k miles on it), but I've never noticed any issue with it starting, even through last winter's brutal cold.
  5. PriusCamper
    11,059
    4,502
    Use the MFD to get a sense of battery voltatage while it's under load. If it gets lower than 12.6 volts it's probably time. Also to extend it's lifespan get a cheap $10 trickle charger... They charge the battery up to ~13.8v and if it can't hold that charge after sitting unused for a couple days, that's another sign it's time.
  6. cutter44
    cutter44 Member
    213
    MA
    Well, it never sits unused. Only time was when we were on vacation for a few days. Normally it's drive 80+ miles per day.
  7. Matt H
    Matt H Active Member
    164
    104
    Okinawa Japan
    2012 Aqua
    Which is why Toyota recommends changing the aux-battery in their hybrids every three years. It's part of the normal maintenance schedule. You could probably get away with four pretty safely, but if you want a well maintained car that won't leave you stranded, I change the batteries in all of my hybrids every three years, along with the key FOB batteries.
    Problem with batteries, is that you can test a battery with a battery tester, and it'll prove OK. Three days later, it isn't.
  8. cutter44
    cutter44 Member
    213
    MA
    Saw the 51-440BAGM Bosch Battery mentioned in a previous thread. People here still like that one or are there other recommendations?
  9. fmerkel
    fmerkel Member
    88
    46
    Seattle, WA
    Do you have a number or more details than AGM 12v? I think that covers a lot of ground.
  10. PriusCamper
    11,059
    4,502
    Lol... Most 10 year old Prius are so well designed they're driving on original battery simply because there's never a cold cranking amps load. And yes that may not be what's recommended, but it's the truth, I've seen it again and again and again... That's why it's the first repair issue to be addressed before all the others!
    #10 PriusCamper, Aug 15, 2018
  11. PriusCamper
    11,059
    4,502
    Here's the most recent one I bought for my friend, they change from time to time, but they're pretty much same size and amp hour, at least in the US: Duracell Ultra 12V 55AH AGM SLA Battery with M6 Terminals
    SLAA12-55C/FR
    fmerkel likes this.
