12v battery 12.2v off, 14.1v running - advice
Discussion in 'Gen 2 Prius Technical Discussion' started by gptoyz, Jan 11, 2019.
  1. gptoyz
    gptoyz Junior Member
    79
    16
    los altos
    So I just bought another rehab prius 2007 with 237k miles
    Checking through the self diagnosis menu I see that the 12v battery has the following conditions:
    12.2v systems on, engine off
    drops to 11.8v when the engine is powered on
    14.0 - 14.1v when the engine is running but never exceeds that
    I have no history on the car, so I'm just trying to get an idea if I should blindly replace the battery or if I'm good to go.
    I already have an appointment to get the HV battery replaced under warranty
  2. JC91006
    16,474
    8,393
    Warranty on the battery? Didn't know they are transferable.
    Your 12v probably only needs a good charge, or you driving the car for a week should do the job
  3. gptoyz
    79
    16
    los altos
    thank you for the advice
  4. Mendel Leisk
    38,644
    Hook it up to a smart charger, something in 3~4 amp range, let it run to completion. If it stalls, never completes, say after 12 hours, or shows some sort of error code, time for a new battery. Assuming it does complete: drive the car for a few days, then test battery with Solar BA5 or similar; it'll give a "verdict".
  5. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    Is this an aftermarket battery?
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    The factory one is.
    But it certainly is NOT good for 237,000 miles.
    I suspect that his 12V is on the way out too.
    I certainly wouldn't trust it with those numbers.
  7. Skibob
    2,912
    1,496
    Northern California
    12 years? I thought 10 years was max?
  8. sam spade 2
    7,035
    2,788
    2017 Prius c
    That too.
  9. ChapmanF
    15,433
    The OP mentioned reading these voltages "through the self diagnosis menu", i.e., on the MFD.
    Given we know that measures voltage a bit over half a volt downstream of the battery (in ACC or ON; in READY it's actually upstream), those numbers are splendid and my advice would be to enjoy the car, unless it has given you any specific reason to question the battery.
    padroo, Mendel Leisk and jerrymildred like this.
  10. sam spade 2
    7,035
    2,788
    2017 Prius c
  11. Mendel Leisk
    38,644
    Invariably these questions are really "I'm in the dark about my battery condition" guess sessions.
    padroo likes this.
  12. Skibob
    2,912
    1,496
    Northern California
    Haha I use the rubber bands from my vegetables too. ;)
  13. Mendel Leisk
    38,644
    Get brocolli. Eat or throw away brocolli. Use rubber bands.
    My Milwaukee actually has clips for the probes on the back, but as far as I can see they're useless. I've tried various permutations, wrapping the leads this way and that: hopeless: get brocolli.
    Skibob likes this.
  14. Mendel Leisk
    38,644
    Brocolli probably trucked all the way from Cali or Mexico, and what do I do...
  15. sam spade 2
    7,035
    2,788
    2017 Prius c
    IF......you wrap the leads around the case the other way, around the narrow sides.....they will soon take on that shape and will pretty much stay put with NO extra tie-wraps at all.
  16. Ernest Erickson
    Ernest Erickson New Member
    16
    Arizona
    Technology
    12 V, normal resting voltage for most lead acid batteries.
    The higher charge voltage is for overcoming the internal resistance of the plates, so the charging requires 14 + volts.
    If you read under 12 V when the battery is not connected, then you might consider replacement, but always perform a good charge cycle, depending on usage. a long rest period will drain every battery over time.
    Solar chargers are great, and I use this method a lot.
    The Prius shuts off the 12 volt ports when you shut down, so this is not an option.
    My Olds Silhouette, did not suffer this, so I left my panel connected full time...never had a problem with the battery.
    Heat is the worst enemy to batteries, and living in Arizona, one must be aware of this failing.
    If possible, always try to park where the hood is covered by foliage or something.
    And no, this 'trick' fails on Prius...there is no battery under the hood.
    Proper care and feeding of your batteries will provide long life, and few worries.
    Live long and prosper!
    Spock...out.
  17. gptoyz
    79
    16
    los altos
    Thanks everyone for the advice. to answer the HV battery is aftermarket, but the previous owner made the appointment for me and the company agreed to take care of the swap - pretty cool!
    as far as the 12v, I will have to check if it's aftermarket or not. But I came across a great deal on a GS Yuasa which is why if the 12v were borderline, I would jump on it!
  18. bisco
    49,371
    where? inquiring minds want to know!:)
  19. sam spade 2
    7,035
    2,788
    2017 Prius c
    Wisdom this was NOT.
    Nominal fully charged resting voltage for "most" lead acid batteries is 12.6; higher for an AGM.
    12.0 is about half discharged.
    It does not take 14+ volts to charge. Float voltage is about 13.2 and anything above that will charge a little; the higher the voltage, the more charging.
