12v battery alternative?
Discussion in 'Gen 2 Prius Main Forum' started by 05 200k prius, May 21, 2015.
  1. 05 200k prius
    05 200k prius New Member
    Birmingham
    After doing much research on this site, I have found this.
    And I think it will work. 33$ sounds awesome as opposed to 150$. I understand I will need to change terminals. I have found a good write up on how to do so.
  2. 05 200k prius
    Birmingham
    Batteries plus has the battery. Part number 45215-5-dot5Ah-12-Volt-Duracell-Ultra-AGM-Battery-DURA12--5-dot5F
  3. 05 200k prius
    Birmingham
    Sorry I am not allowed to post link yet because I am a new member
  4. se-riously
    se-riously Active Member
    263
    114
    SF Bay Area
    2014 Prius Plug-in
    Are you honestly comparing a 5.5 ampere-hour battery to the factory 28 ampere-hour one? If you're car has smart key, or you run any accessories without the car on, or haven't driven the car for a while, it's safe to say that the 5.5 AH will be very quickly drained.
    theshark, dolj and valde3 like this.
  5. dolj
    dolj Senior Member
    8,209
    4,180
    Wellington, New Zealand
    The OEM battery for non-SKS models is 35 aH and the one for SKS models is 45 aH.
    He could put 6-8 Duracell batteries in parallel. (y)
  6. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    if you cant afford $150 for the correct battery every 5 years you cant afford any car.
    you might as well put a riding lawn mower battery in it for $29.95 and pray.
    im cheap but DAMN! :cool:
    maybe just leave the hatchback open like a sail and on windy days you can go for free
    #6 Beachbummm, May 21, 2015
    theshark likes this.
  7. wjtracy
    wjtracy Senior Member
    11,360
    3,606
    Northern VA (NoVA)
    I don't think we have any reports of someone trying something like this, so it does not sound like a good idea, and furthermore you'd be on your own. Probably better budget basement approach is finding a used batt I suppose sometimes they have life left. Some have lasted a long time if well kept.
  8. bisco
    51,141
    i guess of 33 bucks its worth a try. what does the b plus guy say?
