12v battery and code P0A80
Discussion in 'Gen 3 Prius Technical Discussion' started by daley, Dec 16, 2024.
  1. daley
    daley Junior Member
    58
    Knoxville
    Hi there,
    I have.a gen 3 with nearly 200k miles on it and I got the code’ pull over and check hybrid system’
    My 12v battery has been bad for a couple of weeks, I have had to put it on charge overnight otherwise car wouldnt start in the morning.
    When I got the code I assumed my hybrid battery to be dead, however having replaced the 12v battery the code has gone and now shows as ;inactive; on my code reader.
    Is it possible for a bad 12v battery to trigger the hybrid battery coide?
    I am still expecting to need to replace the hybrid battery soon but if it can live a little longer, that would be handy.
    51,141
    yes, it is possible
  3. Brian1954
    Brian1954 Senior Member
    1,804
    711
    South Central PA, USA
    It is possible, but not probable. Just drive the car and see if the P0A80 code returns again. If it does, a replacement HV battery is in your future.
