12V Battery Charger Question
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by vinnie97, Jan 1, 2012.
  1. vinnie97
    vinnie97 Whatever Works
    1,430
    277
    Somewhere out there
    I hadn't researched this extensively yet in the case of the Prius, but due to its unique design, is the cigarette outlet a valid place to trickle charge the 12V battery on the Gen III? I was considering a battery like this: Shop Stanley 2-Amp Battery Maintainer and Charger at Lowes.com
    However, it may be required to connect it to the battery terminals themselves, but I just wanted to ask the experts before making any assumptions. I realize this wouldn't be a solution for emergency jumps, so perhaps either a 6-amp or 15-amp charger would be more appropriate for those occasions?
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    You cannot use the 12v power outlet to charge the battery, it is disconnected when the power is off.
    However, you do not need to attach directly to the battery terminals either (the battery is hard to access directly in the back of the car). There are connections for jumping (or charging) under the hood and that is shown in your owner's manual.
    2 people like this.
  3. vinnie97
    1,430
    277
    Somewhere out there
    'Preciate it, I recall there being some battery access under the hood. I'll consult the manual and forget the 12v power outlet idea. ;)
    PS. What is a sufficient amperage charger for a typical 12v car battery?
  4. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Yes you can charge a small battery from the accesory plug, I do it often when I am on a trip. I use a small block, sealed, alarm battery 7AH I wanted to see just how good it was in a emergency, and keep it under the right seat when not in use ( generally the case ) Evan is correct that no 12V is there when the car is OFF, good thing! So your choice, you can leave it connected or remove it. Incidently when the car was new I drove with this battery about 8 miles, connected to under hood terminals with the regular 12V disconnected. :cheer2:
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    The OP was asking the other way around: they want to charge the 12V battery in the Prius from the accessory jack, not charge a battery *from* the jack. This will not work without modification.
    Tom
  6. andyprius
    2,212
    188
    Agree, that's a output. ???? I don't see the purpose, the HV is charging the 12V. When the car is off, so is the accesory plug.
  7. vinnie97
    1,430
    277
    Somewhere out there
    The purpose would be in the event the 12V dies, and I need to recharge it. ;) Andy, are you claiming the hybrid battery actively charges the 12V when the vehicle is off? I don't think you were implying that because I don't believe that's correct...
  8. andyprius
    2,212
    188
    No, the 12V bat is getting a charge from the HV, at that time 12V is present at the accesory plug. As I said it's a output. And never an input.:D To answer your original question, the 2 anpere from Lowes would probably be OK, I believe the recommended is 3 Amps or less / about once every 6 months.
  9. Willem
    Willem Junior Member
    51
    I wish I saw that before I dismantled the rear deck to gain access to jump my wife's VW.
    It was in my driveway, but it was dark, windy and drizzling rain. Under those conditions, my (cheap) LED flashlight did not reveal such an option. The only thing I saw was a reference to the 12-volt battery being in the back.
    And getting all the shrouds and associated stuff back to where it was before exposing the battery was not easy.
    Lesson learned: Read the Manual!
    Thanks again, efusco!
  10. richard schumacher
    7,664
    1,043
    United States
    Whoa, whoa, whoa: you shouldn't be jumping *from* a Prius *to* anything else. The Prius' 12V battery, wiring harness, controller, fuses, and inverter are not up to that task. Doing it the way you did it, directly from the Prius battery, is the least risky way, but you were lucky if the jump worked and everything on the Prius still worked afterwards.
  11. vinnie97
    1,430
    277
    Somewhere out there
    Right, thanks. I don't let the car sit for extended periods, so I should be okay with getting a more robust charger with a higher amperage (that can top off the battery in 30 minutes as opposed to 30 hours ;)) for emergencies. Would a 6-amp or 15-amp be sufficient for this purpose?
  12. jdenenberg
    jdenenberg EE Professor
    3,926
    1,923
    Trumbull, CT
    2020 Prius
    LE AWD-e
  13. vinnie97
    1,430
    277
    Somewhere out there
    It looks that it can be 4.2 Amps or under, according to the manual:
    I still wonder if a charger with higher amperage (I bought this one for at-home emergencies: Shop Stanley 6-Amp Automatic Battery Charger with 8-Amp "Quick Start Timer" at Lowes.com) would be suitable in the rare event the battery is unexpectedly drained.
  14. Mendel Leisk
    40,575
    I've got a 6 amp "automatic" charger. Haven't been using it much lately, using instead a 1.5 amp CTEK charger, but I recall the 6 amp would show a charging rate around 2 amp when I used it. Due to the automatic feature at work?
    tangerino likes this.
  15. vinnie97
    1,430
    277
    Somewhere out there
    Yes, it sounds to me that feature would prevent any untoward unsafe rapid charging of the battery, and your experience confirms.
