12v battery connection question.
Discussion in 'Gen 2 Prius Main Forum' started by Infamous6i9, Feb 26, 2019.
  1. Infamous6i9
    Infamous6i9 Junior Member
    61
    Los Angeles
    I cant find anything on here so ill ask.. its been happening recently in my 2004 prius. But when ever i turn off the car all the power dies. So i go to the trunk from the rear passenger seat and when i touch the white connector thats on the positive terminal fuse link or just tap it all the power comes on again.. is there something i should replace. Or could it be something that needs to be tightened.. tia
    #1 Infamous6i9, Feb 26, 2019
  2. ChapmanF
    15,765
    Quick stuff first - is that connector plugged in all the way? Squeeze it, pull it out, push it all in 'til the solid click?
    Not an ideal connection to have loose....
    Infamous6i9 and SFO like this.
  3. kens97uber171
    kens97uber171 Active Member
    177
    132
    US
    I agree with the second comment, push in the release take the connector all the way out and push it all the way back in until you hear is solid click. That one is a bit of a pain to get off and on and it's possible that someone previously didn't get it reconnected completely.
    Infamous6i9 likes this.
  4. Infamous6i9
    61
    Los Angeles
    Yea i just did it right now. Removed it. And bent the locking part a little so its more secure.. plugged it in and heard a click.. will do more testing.. also i did not put the red cover on just incase all power goes off. Thats safe to do right.
  5. Infamous6i9
    61
    Los Angeles
    Thanks i have now done that for further testing
    kens97uber171 likes this.
  6. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    I don’t think there is anything metal above the terminal so you should be fine.
  7. Infamous6i9
    61
    Los Angeles
    Update. Well it turned iff again. Im assuming its the wire where the white part connects to is loose. Ill have to check it out tomorrow morning. It inky started happening the day after i decided to do the chicken dance to get a used key fob to work.. SMH
  8. Skibob
    2,912
    1,496
    Northern California
    Does it happen with your regular key fob?
  9. Infamous6i9
    61
    Los Angeles
    Yea. I never fully got the unlock function to work on the spare emergency key i set up. So ive been using the old one.. but i recently changed the whole positive connector hopefull that will fix the problem
