12v battery dead, with maybe other problems
Discussion in 'Prime Main Forum (2017-2022)' started by randerson9248, May 22, 2020.
  1. randerson9248
    randerson9248 Junior Member
    66
    SF Peninsula, CA
    2017 Prime has been sitting for 3 or 4 days. 12v battery is now dead. I put a 6amp battery charger on it about an hour ago. Just went to check on it and there is a barely noticeable buzzing/clicking noise coming from near the under hood fuse box. Should I be worried about the noise?
  2. Salamander_King
    Salamander_King Senior Member
    11,009
    8,935
    New England
    If your 12v is charging up you maybe OK. I am not sure of the sound you are hearing but it maybe a normal noise associated with traction battery control and other thing that runs automatically while car is parked. PRIME seem to have phantom draw on 12v while sitting, but 3-4 days for dead 12v is very short. Your 12v battery may be on the last leg. If you can't resurrect it, you may have to get a new battery.
    Read-up on this thread to learn more about 12v AUX battery care on PRIME.
    12v Battery Is Discharging, Re-Charge Now ! | Page 12 | PriusChat
    Rob43 likes this.
    51,155
    it's probably an always on device that is starting to come up to operating voltage
    Montgomery likes this.
  4. FuelMiser
    FuelMiser Senior Member
    1,342
    922
    Monument, CO
    Buzzing/humming should not be a problem, but I would be worried about clicking. My battery maintainer is 1.5 Amp. I am no electrical engineer, but could 6 AMP be too much? Also, if you're worried about the sound, disconnect the battery from the car (remove and wrap the negative terminal, after disconnecting the charger, of course) then resume charging it up...
  5. randerson9248
    66
    SF Peninsula, CA
    Once battery charge came up the noise stopped. Charged the battery overnight, but did not drive until today. Now I have 2 warnings: 1. Hybrid battery malfunction (still shows same charge in miles (17) as before the 12v battery went dead). 2. Pre-collision system malfunction.
    Will these warnings go away after a few drive cycles?
  6. bisco
    51,155
    if not, try disconnecting the 12v neg for a minute. if that doesn't work, you'll have to shut them off with an obd tool.
    Rob43 likes this.
  7. randerson9248
    66
    SF Peninsula, CA
    Threat wrap-up:
    Thanks everyone. After 4 drive cycles the warning messages are gone.
  8. randerson9248
    66
    SF Peninsula, CA
    Oops: Thread wrap-up: not threat
    Montgomery, benagi and bisco like this.
  9. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    Not for a car battery. 10 amp would be fine. All modern chargers are automatic...they reduce the charge rate as the battery charge level rises.
    Have you checked the liquid level inside the battery cells? You can remove the caps with a large coin and look inside. If the electrolyte level is below the tops of the grids it absolutely needs distilled water added. You can add the distilled water up to the indicator. Look into the access port of a cell. You'll see a kind of a tube from the top down a short distance with a slot in the side. After the battery is charged distilled water can be added to bring the level up to the bottom of that tube--you'll see the curvature of the meniscus when the liquid level reaches it. Add No More! (Topping up the water before charging might result in over-fill.) Keep the top of the battery clean and dry. Don't get dirt into the cells.
  10. Mendel Leisk
    40,584
    What kind of 6 amp charger? Old-school bought in the '70's, or an up-to-date "smart" charger?
    There is an amperage limit in the 4th gen Owner's Manual, but do you think I could find it... IIRC it's saying 5 amp max??
  11. ChapmanF
    17,347
    Note that it's about a 45 amphour battery (I'm going by what's in a Gen 3, I don't actually know what they put in Gen 4), so if it was doornail dead and you're charging it at 6 amps, one hour is way early to check on it. If charging were 100% efficient you'd be looking at 7½ hours. Charging isn't 100% efficient, so a good 12 hours is more like it.
