12V battery dead.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kristen Hicks, Mar 27, 2014.
  1. kristen Hicks
    kristen Hicks New Member
    Los Angeles, California
    second dead battery in 2 years. ??? Car never sits for longer than 12 hours and no internal lights on. I have a III with Sunroof. Anyone?
  2. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Any non oem accessories like a scangauge, or BT reader plugged into the OBDII port?
    No DTC codes reported?
  3. JC91006
    16,474
    8,393
    Brand of battery? Toyota batteries have 24 month warranty, optima has 3 years warranty. Chances are you can just recharge your battery and see how it holds up.
    49,358
    welcome to priuschat! you'll need to test the battery with everything off to see if there is a parasitic drain. all the best!(y)
  5. kristen Hicks
    No DTC codes reported. The main battery and also the solar run. Had to use key to enter car. Tried charging but doesn't hold. First battery went at 39K miles. Replaced by dealer for $300. This one is just a year old. I have another 2010 prius 3 that seems fine. Is there a way to diagnosis before failure. In the "OLD" cars we would do battery tests every 6 months.
  6. JC91006
    16,474
    8,393
    I would get the warranty replacement from Toyota, they should have a 24 month warranty on their batteries.
    You should remove the battery from the car and charge it up. After fully charged, wait 2 days and take a voltage reading. If it's holding a charge, then you would assume there is something draining it in the car.
  7. Mendel Leisk
    38,634
    Just to clarify: these are Toyota spec'd batteries, ie not a third party battery, an Optima or whatever?
    One rudimentary test is to hook up a digital multimeter, check the voltage, with the car off. A 100% battery will be around 12.6 volt or higher. 12.5, 12.4 is getting iffy. 12.3 and down not so good.
  8. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    I bought a 12v from the dealership in New Mexico last week. It cost ~ $190 - 200 USD but it now carries a graduated 84 month guarantee. Much better value overall than the 12v batteries of yesteryear that cost ~ 140 USD but only carried a 3 or 4 year warranty.
  9. kristen Hicks
    AWESOME INFO everyone. Many thanks!!
  10. Pepelily
    Pepelily Junior Member
    34
    Georgia
    i replaced my battery 2 months ago and this morning my battery was dead, i jumped it, drive around a little , turned off car and after 40 min tried to start the car and was dead again so i went to autozone to have it checked and they told me the battery was bad, it did not have any charge and wont take any charge if they tried, so i went to toyota and they give me another one, i installed it by 5pm , it is 9 pm i went outside and unlock my car and seems to be good. i did not turn it on but lights when locked it seemed strong and the lock bip was fine too, i hope it was only the battery i will try tomorrow.
  11. Pepelily
    34
    Georgia
    mine died in two months so dont feel that bad
    i replaced my battery 2 months ago and this morning my battery was dead, i jumped it drive around a little , turned off car and after 40 min tried to start the car and was dead again so i went to autozone to have it checked and they told me the battery was bad, it did not have any charge and wont take any charge if they tried, so i went to toyota and they give me another one, i installed it by 5pm , it is 9 pm i went outside and unlock my car and seems to be good. i did not turn it on but lights when locked it seemed strong and the lock bip was fine too, i hope it was only the battery i will try tomorrow.
  12. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    For anyone having battery troubles:
    New batteries need to be FULLY charged before being put into service.......or shortly after.
    This can be done in the car or out.
    You should NOT trust the dealer or the car to do that for you.
    And vehicles that are not driven much.......that are off more than they are ON.....,would benefit from an automatic smart charger connected to the battery at least once a week to "top off" the charge.
  13. Pepelily
    34
    Georgia
    thanks a lot
  14. Mendel Leisk
    38,634
    Get something like a CTEK 3300 charger, hook it up overnight on normal setting. If it shows green light the next morning you should be good. Drive it for a few days, then check voltage with a digital meter.
  15. Pepelily
    34
    Georgia
    thanks to you all
