12v battery dead
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Sebpercu, Jul 30, 2021.
  1. Sebpercu
    Sebpercu Junior Member
    San antonio
    My 12v is dead, 4v this morning after 3 weeks holidays... battery was already capricious before that and refused to start the car mostly when i was driving small distances> I tried to charged but the "smart" chargeur doesn't want to do it and put itself in security, so i imagine my battery is definitely dead.
    I saw few post talking about an Ebay battery at 100$, 12 Volt (12V) 55 Amp (55Ah) VRLA AGM Sealed Lead Acid Battery 55 AMPS HIGH CAP
    Any informations about it ? looks likes it need so adjustments to install. any advices ?
    thank you!
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,504
    6,593
    Texas Hill Country
    Most of us go for reliability and want an agm that fits with proper terminals and has a vent port. Both of which will be missing with the wheelchair battery. You can get one that fits with an aftermarket auto supply equivalent that might last 3 years or a Toyota oem battery that will last 7 years. Try negotiating with the dealer's part dept, not the service advisor by asking for a discount.
    52,388
    i have read about some desulfating chargers that will bring your 12v back to life. check you tube
  4. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
    how old is your battery? Sounds like it’s got some miles on it. I’m assuming it’s not under any sort of prorated warranty. You can easily check date code on battery. so my advice is bite the bullet, buy a new one and live in peace a few more years. If any warranty months left there may be some money in it. Some are out to 72 months new.
  5. Mendel Leisk
    41,900
    @Sebpercu : if you know, how old is your battery?
    BTW: "AGM" (Absorbent Glass Mat) batteries main feature is that they are much less prone to vent noxious gasses. I believe that's the main reason Toyota went with that style of battery. Also, if the you're in a collision, hit from behind, there's much less risk of spilled battery acid.
  6. Sebpercu
    San antonio
    The battery looks very old, 7v after regeneration and charge. Checked the date code and it looks like it was from 2015 (the 5 is scratched, so i think it is 2015 and not 2005 lol)
  7. Sebpercu
    San antonio
    Mine is doing it, but didn't work this time. I will have to buy a new battery unfortunately
  8. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    The smart charger doesn't like low voltage, best to find a old school dumb charger and bring the battery up to 10V+, then switch over.
  9. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    While that is true, it is HIGHLY likely that it won't hold a charge even after it appears to be fully charged.
    That might be a good plan IF your objective is to get it started once.......so you can drive it to a battery store !!
  10. sam spade 2
    7,035
    2,804
    2017 Prius c
    BUT......that is mostly just marketing hype and any positive results will be short lived.
    AND......it won't work at all if sulfating is not the original problem.
  11. bisco
    52,388
    i saw it on youtube, it must work
  12. Mendel Leisk
    41,900
    A battery of dubious age, currently reading 7 volts, that a smart charger won't stoop to charge? It's time.
  13. Another
    1,819
    517
    Naples, Florida
    Get a new Toyota OEM battery and get on with life. Many dealers have sales on them periodically. Check dealer websites for service specials.
  14. Another
    1,819
    517
    Naples, Florida
