12v battery died; now fuel gauge at 1 bar and blinking
Discussion in 'Gen 2 Prius Technical Discussion' started by PensacolaRevitup, Dec 30, 2020.
  1. PensacolaRevitup
    PensacolaRevitup New Member
    Pensacola, FL
    My '09 got t-boned in the right rear (not too serious). Ended up sitting for 2 weeks, and some idiot left the dome lights on. Dead 12v. Recharged 12v. Now fuel gauge only showing 1 bar and blinking. Tank is 3/4 full.
    Ideas? TIA!
  2. dolj
    dolj Senior Member
    7,447
    3,750
    Wellington, New Zealand
    Assuming that no one helped themselves to your gas, it will take a few drive cycles for the fuel system to recalibrate itself. This is quite normal after the removal and reinstatement of 12V power. It can be anything from 5 minutes to 5 days.
    PensacolaRevitup likes this.
  3. Mendel Leisk
    38,102
    How old is the 12 volt? If 3~4 years or more hardly worth testing*, just replace.
    * Most automotive retailers selling batteries will perform an electronic load test for free, hoping to get your business. Dealership will too, for maybe $75? Google solar ba9 for one DIY option.
  4. mr_guy_mann
    mr_guy_mann Senior Member
    3,203
    1,337
    NJ-USA
    Assume nothing. I would fill the tank asap so you know that the tank is full. It is possible that the fuel gauge sending unit in the tank is on its way out. I have replaced 2 or 3 tanks in the past couple months just for that. Or something happened to the wiring. Or the level is actually that low.
    Also suggest having the 12V battery load tested.
  5. PensacolaRevitup
    Pensacola, FL
    It's a long story, but, yes, someone siphoned my gas. (Jerks)
    All is well once again, after filling tank and allowing for gauge to re-calibrate (if it actually does that.)
    Seems to be okay. Thank you for your help!
  6. Mendel Leisk
    38,102
    I thought that was nigh impossible to do??
  7. mr_guy_mann
    3,203
    1,337
    NJ-USA
    Very difficult, but it looks to be "possible". It is about 4.5 feet (1.5 meters) from the gas cap past 3 sharp bends, a step down (reduction in diameter where the filler neck conncts to the tank) with another bend and a "trap door" valve before you can reach the fuel in the bladder.
