12V battery died, now hybrid system is not working
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by PriusOwner142, Jan 26, 2025.
  1. PriusOwner142
    PriusOwner142 New Member
    Lincoln
    I went on a trip for a little over 3 weeks. We had some cold weather and my 2004 Toyota Prius would not start when I got back. I jumped it and got it to start but it would not start on its own. The dash lights also did not come on even when I jumped it. I replaced the 12V battery but had the red triangle of death when I turned it on after. I drove it around the block and had noticeably less power and the energy control said my consumption was around 16 mpg instead of my normal high 40s. I am assuming this is because the hybrid system isn't contributing so I am just running off the combustion engine.
    My next thought is jumping it fried the DC/DC converter fuse fusible link and was going to replace that, but I am looking for any advice on what else it could be/how to troubleshoot this issue. I'm not the most knowledgeable on hybrids so links or explanations to any work you recommend me trying would be appreciated.
    51,034
    your best bet is to get a prius aware scanner, and post the trouble codes here.
    Brian1954 likes this.
  3. MAX2
    MAX2 Senior Member
    1,436
    482
    101
    Third planet from the Sun
    Has the high-voltage battery or its individual cells been replaced before?
    Has the 12V battery been replaced before?
  4. PriusOwner142
    Lincoln
    The high-voltage battery was replaced a couple years ago. This was the first time I replaced the 12V since I've owned the car.
  5. MAX2
    MAX2 Senior Member
    1,436
    482
    101
    The red triangle may indicate problems in the hybrid part, including the high-voltage battery. There may be a discharge of some of the 28 modules that create the high-voltage package. To accurately determine the cause, you need to read the errors with a scanner.
  6. pasadena_commut
    pasadena_commut Senior Member
    2,220
    661
    Southern California
    The OP's location is "Lincoln", as in Nebraska? Did the car maybe sit for 3 weeks at subzero temperatures? That can certainly kill a marginal 12V. And it does sound like the 12V because it would start with a 12V jump, but not without one. A (conventional) jump won't do a thing to the HV pack.
    The dash light issue might just be that the capacitor problem in the display (a common and well known issue) happened to kick in. Maybe marginal capacitors don't like to be frozen for weeks either. Then it was reporting 16 MPG after the new 12V battery. Well, what temperature was it? Fuel efficiency isn't great driving slow with a cold gas motor in snow at -10 F. What did the energy display show? Was the HV low, like just a bar or two, with the ICE charging it? That also will lower MPG.
    Finally, red triangle of death. Get an OBD 2 scanner which can read all the codes on this car, or the proper adapter and a copy of Techstream, and read the codes. That will tell you all the problems the car itself is aware of.
    mr_guy_mann and Brian1954 like this.
