12V Battery Drain/Can't Start
Discussion in 'Gen 3 Prius Technical Discussion' started by rowdyboy, Feb 23, 2018.
  1. rowdyboy
    rowdyboy Junior Member
    san diego
    a couple of mornings ago without any prior problems, my 2010 Prius was completely dead. I was able to get to the 12V battery and remove it , recharge to 12.5 V and reinstall it. The dash lit up brightly for a few seconds, the car would not start, and the dash finally faded. The power switch wouldn't turn the dash off, it eventually went dark. When everything seemed off I could hear a definite whine coming from the engine compartment, probably explaining the battery drain. I have again removed the battery to charge it and I'll try to get error codes. Anyone ever had a similar issue?
  2. JC91006
    16,672
    8,518
    If the battery is original from 2010, change it
    Raytheeagle likes this.
  3. fotomoto
    fotomoto Senior Member
    5,629
    3,802
    So. Texas
    Do a load test on the 12v battery. Most well equiped auto-parts stores will do this for free.
    Good Luck!
  4. rowdyboy
    san diego
    Thanks guys - it was the 12V Battery. I recharged it and reinstalled it but I guess it couldn't hold a charge. When I installed a new one it solved everything immediately.
    Raytheeagle and bisco like this.
  5. bisco
    51,141
    congrats!(y)
