12V Battery: Duralast Platinum vs Optima Yellow
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ussyicheng, Jun 25, 2020.
  1. ussyicheng
    ussyicheng Junior Member
    Kansas City, MO
  2. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    I like the black one, the color will Blend into the compartment.
  3. Mendel Leisk
    42,117
    I've got the Yellow Top Optima, will be 5 years old this September. It's going great guns, still shows well over spec'd CCA when load tested. It has led a sheltered life though: our usage keeps dropping, but I keep it on a smart charger pretty much constantly.
    Next time around I might try Canadian Tire's black/rectangular case style AGM offering. I don't think there's a world of difference, as long you keep on top of things, basically don't let it get run down.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    I would NOT pay extra for the Optima.
    No good reason to.......despite their marketing hype.
  5. bisco
    52,636
    oem, 200 buckaroos
  6. SB6
    SB6 Member
    324
    71
    ussyicheng, if you decide to get OEM, see if your original battery is still within the prorated range of the warranty. Could save you a little bit
