12v battery fail on prime.
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Speedman, Jan 4, 2025.
  1. Speedman
    Speedman New Member
    Vegas
    2024 Prius Prime
    Well I got the dreaded, 12v battery fail this morning in my 2024 Prime. Had it towed to the Toyota dealership. The battery was replaced, but the mechanic that worked on my car made a note on my paperwork saying, don't use aftermarket plugins in the front USB ports, that is what drained my battery. I don't understand because when I turn off the car, anything that's plugged into those ports shut off with the car. Mechanic claims they are still pulling power from those USB ports.
    Your thoughts please.
    douglasjre, Gokhan and bisco like this.
  2. BiomedO1
    BiomedO1 Senior Member
    2,725
    1,455
    SacTown, Ca
    I wouldn't worry about it. Your correct, those accessory ports are on a relay and turn off with the car.
    If you encounter this again, tell the idiots to look-up the TSB's related to this issue, before making snap judgements.......
    douglasjre and Speedman like this.
  3. Templeton
    Templeton Member
    207
    58
    usa
    2024 Prius Prime
    SE
    Yeah, the mechanic is just making stuff up.
    Their main job: blame the customer for everything.
    douglasjre likes this.
    51,013
    monkeys assigned to changing 12v batteries are not mechanics
    douglasjre and BiomedO1 like this.
  5. BiomedO1
    2,725
    1,455
    SacTown, Ca
    LoL, we do the same at our facility - assign the idiots to a job where they'll do the least amount of damage when they screw-up. It's not a matter of if, but when......:(:ROFLMAO::LOL::sick::sleep::whistle:
    douglasjre and bisco like this.
  6. Trollbait
    12,310
    Bet the dealer installs trackers on the cars.
  7. Mendel Leisk
    40,454
    If you have a multimeter, and would like to see for yourself what's happening: put in series between the negative battery post and ground, close up the car, fob well away, wait half an hour, see what sort of milliamperes, or amperes, it's drawing. Should be around 20~30 milliamperes.
  8. Gokhan
    Gokhan Senior Member
    5,620
    2,215
    Paramount CA
    They shouldn't be a problem.
    Get a Bluetooth BM2 battery monitor from Amazon or at least a cigarette-lighter voltmeter. The BMS on Gen 4/Gen 5 is very miserly and hardly ever charges the 12-V battery. Therefore, get a battery maintainer like a Noco Genius to occasionally bring the SOC to 100%, as the BMS never does so and the SOC can keep going lower and lower with ever-increasing sulfation especially if the car is not driven for at least one hour a few times a week.
  9. Paul Gregory
    Paul Gregory Senior Member
    1,357
    355
    Alberta
    2024 Prius Prime
    XSE
    If your USB sockets are live when your car is turned off, I'd like to know how you do it.
    My USB sockets are off whenever I stop my car, and it's a bit of a pain sometimes, when I wish they'd stay on.
  10. Paul Gregory
    1,357
    355
    Alberta
    2024 Prius Prime
    XSE
    I think I'd be looking for a different mechanic. If he hasn't bothered to actually measure parasitic drain through your USB sockets, it sounds like he's just guessing.
  11. bisco
    51,013
    i suppose if you plug something in using max usb power when the car is ready, it might leave the 12v a little lower than if you didn't, if the inverter can't keep up, idk.
  12. Paul Gregory
    1,357
    355
    Alberta
    2024 Prius Prime
    XSE
    I believe the USB ports are limited to 15 watts. The inverter is rated for 100 watts, I think, so it's unlikely that USB power will draw down the system.
  13. bisco
    51,013
    you're probably right, but the inverter is covering a lot more than the usb.
  14. Paul Gregory
    1,357
    355
    Alberta
    2024 Prius Prime
    XSE
    Just a side note: I think it's a DC to DC converter, not an inverter.
  15. bisco
    51,013
    right again, i can never remember that
  16. DOHCtor
    DOHCtor Member
    155
    89
    Levis (Quebec city's south shore)
    2024 Prius Prime
    SE
    Nah. Those OE grey batteries are junk.. we change more or less 3 a week on warranty. Mine lasted a week before dying, some are getting replaced during PDI, my sisters Priuses batteries lasted 6 months and 2 years.. the replacement C0PBS-6H4MF is tougher and lasts wayy longer then that..
  17. Paul Gregory
    1,357
    355
    Alberta
    2024 Prius Prime
    XSE
    I'm wishing for fast charging through the USB C sockets. So far it looks like they are only putting out 5 volts.
