12v battery. How is it charged?
Discussion in 'Prime Technical Discussion' started by Dmitriy Sokol, Mar 3, 2017.
  1. Dmitriy Sokol
    Dmitriy Sokol Active Member
    112
    108
    Annapolis, MD
    Does anyone know if the 12v battery is only charged by ICE? What happens if I use EV mode for weeks, without ICE kicking in? Would it be beneficial to trickle charge it once a week or so? Thanks!
    iPhone ?
  2. 34Hupp
    34Hupp 1934 Hupmobile - Americas 1st Aerodynamic
    62
    100
    Rochester, NY
    #2 34Hupp, Mar 4, 2017
    Dmitriy Sokol likes this.
  3. fuzzy1
    10,170
    That isn't true of any previous Prius, so it seems highly unlikely for your Prime.
    If charged only by the ICE, the 12V would become a problem within a very few operating hours, not weeks.
    Chaughten and Dmitriy Sokol like this.
  4. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    It's charged by the power conversion unit that sits not far from it. It is the transmission and alternator of the car. It has it's own liquid cooling system.
  5. bisco
    49,490
    it should also charge when plugged in. unless they changed it from the pip.
  6. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Lets assume that the 12 volt battery is charged in a similar fashion to other Prius. In that case this (boring) demo goes over it from 15:10 to 18:00 (on the Prime the 12 volt battery is under the hood, not as stated for the Gen 2, in the back hatch)
    WilDavis and Andyprius1 like this.
  7. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    A great explanation. TY
    In layman’s therms. A potential of 14.5 volts, about becomes available when car is in ready. If the 12V requires charging then current flows and returns the battery to design level. When both sides, the Dc source
    and the 12V are equal, current ceases to flow and charging is complete. Until the next microsecond.
    The charge you showed looks great.
  8. Andyprius1
    2,327
    859
    Cool CA
    I think you are right.
  9. Mendel Leisk
    38,726
    It would still be worthwhile to hook up to an external smart charger, if the car regularly sits for a day or three.
    Andyprius1 likes this.
