12v battery is charged. Lights on my window switches are blinking.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jay C., Jul 9, 2020.
  1. Jay C.
    Jay C. New Member
    New Orleans
    Great community with wonderful information. I have been reading threads but I haven’t seen this problem addressed. I was having difficulties with my 2012 Prius coming on 109k miles roughly. So I took the battery to the nearest neighborhood O’reillys. They charged the battery and it’s coming on now but now the lights in the window switches are blinking. If anyone could help it would be great! Thanks
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    Disconnect the battery again for a few minutes.
    AND.....if that it the original battery from 2012......or is more than 5 years old, replace it.
    Just charging a battery will NOT magically bring it back to life for very long.
    kenoarto and tankyuong like this.
  3. ChapmanF
    15,588
    Blinking window switches usually means the power was out for a bit and the windows forgot where up is.
    I think the procedure to re-teach them is even in the owner's manual somewhere, not just the repair manual.
    If I remember right it's just a matter of rolling all the way down and back up, but holding the switch in place a few seconds at each end.
  4. Jay C.
    Jay C. New Member
    New Orleans
    Thanks for the information I’ll be sure to make sure to reset them.
  5. Jay C.
    Jay C. New Member
    New Orleans
    Thanks. The battery isn’t the original so I’ll make sure to disconnect it and follow your advice.
  6. ChapmanF
    15,588
    Then you'll have to teach the windows where up is again. :)
  7. sam spade 2
    7,035
    2,788
    2017 Prius c
    The "disconnect it again" was just a wild guess.
    So unless the battery is OLD, just follow the OTHER better advice.
    Jay C. likes this.
  8. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    Okay windows, listen up. When I pull & hold these switches up, you go up. When I push the switches down, you roll down. Any questions windows? No? Okay let's hit the road.
  9. ChapmanF
    15,588
    Boy, remind me never to be one of Grit's windows.
    SB6 and Raytheeagle like this.
  10. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    Revenge is had when changing transmission fluid;).
    It makes for a nice hair gel:ROFLMAO::LOL::ROFLMAO::LOL:.
