12V Battery Issue
Discussion in 'Gen 2 Prius Technical Discussion' started by EvelynC, Jun 23, 2014.
  1. EvelynC
    EvelynC Junior Member
    I think one of my family members left our 2006 Prius on overnight. Now the doors won't open except with the key and the car won't start. Can the auxillary battery be charged with a battery charger like on a "normal" car? :)
    Thanks!
  2. Epiphany2000
    Epiphany2000 Member
    126
    San Francisco Bay Area, CA
    Yes, it can. However, like most other 12V batteries, it might not work very well after it has been fully discharged.
    The manual (at least in my 2005) recommends disconnecting the negative terminal from the ground before charging. Also, do not charge the battery with a current higher than 3.5 amps.
    Good luck!
    49,371
    If you jump it from another vehicle, Do not cross up the positive and negative. This can cause damage to the inverter. You can also charge/jump at the fuse box under the hood.
    49,371
    How old is the battery?
