12v Battery Keeps Dying
Discussion in 'Generation 1 Prius Discussion' started by maverick4u, Dec 14, 2017.
  1. maverick4u
    maverick4u Junior Member
    usa
    2003 Prius
    I
    OK-I have a 2003 Prius I'm trying to bring back to life. A drunk driver ran into my car while parked on the street and pretty much totaled it. After sitting for 2 yrs, I've been trying to fix it up for my 16yr old son and I got it running again. However, after parking it for a couple of days my 12v starter battery (the small one in the trunk) keeps going dead. The battery is a brand new one from elearnaid (the Deka one).
    The trunk light does not stay on after closed, the key Fob does not remotely lock the driver side door but does all the others. I suspect the latch is boogered..
    The red triangle of death comes on so I suspect my Hybrid battery has some bad cells in it. Would this cause the starter battery to parasitically drain?
    Also I noticed that my radio goes out and if I reset it by disconnecting the (brand new} negative terminal it works for a while then goes out again. Could this be a bad ground and also be parasitically draining the starter battery?
    Thanks for any help!
  2. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    Welcome to PriusChat! You've certainly come to the right place to find answers. You might update your info. so that folk can see where you are, and being that the cold season is just starting (here in the NE USA, anyway) always remember that the AuxBattery (12V) works on a chemical reaction which is very dependent on temperature, so as the temps. drop, they don't perform as well. That, plus the AuxBattery is rather small, which is another disadvantage. It sounds like the battery is being drained (light being left on?) plus the SKS system (if fitted) can drain a weak battery (but can be temporarily disabled). In fact I replaced the AuxBattery on my 2009 Gen II 2 years ago (at the time it was 6 years old (normally their life is around 4 to 5 years) and the first symptom I noticed was the SKS started getting flakey! Good Luck, I'm sure you'll soon find the answer, but beware, PriusChat can be addictive! :eek:
    Prodigyplace likes this.
  3. maverick4u
    usa
    2003 Prius
    I
    Thanks...I'm from Illinois which can have truly rotten winters. My rear right power window mechanism broke one winter because the window was frozen shut!
    But what is the SKS? Ho exactly how is the aux battery charged since the Prius doesn't have an alternator...it uses the inverter from the hybrid battery? So if the hybrid battery is going out then it won't charge the aux battery correctly?
  4. Lucifer
    Lucifer Senior Member
    1,014
    485
    Nh
    Guessing the accident caused a hot wire to be grounded somewhere, the sks is the remote system that looks and unlocks the car, disabling it stops it from using the 12 v battery. Might be worth letting Toyota hook up their computer to see it it finds the drain.
  5. Mendel Leisk
    38,664
    You can put a multimeter in series between negative post and ground, see what the "background" amperage draw is.
    WilDavis likes this.
  6. WilDavis
    2,492
    2,153
    49
    Smart Key System - if fitted, information should be in manuals. The 12V AuxBattery is charged by the TractionBattery - see
    (…skip to 17:00) - it's a bit long, but very useful in learning how the amazing Prius works (there are tons of videos on youtube if you have the time) :)
    Raytheeagle likes this.
  7. Dxta
    Dxta Senior Member
    1,932
    766
    Lagos
    The 12volt battery, has no capacity to drain the hybrid battery.
    If its showing the red triangle light, its likely a or some weak cells.
    Scanning the car for codes, would help narrow down the problem.
    A new battery draining? The only reason would be a short circuit somehow in the 12volt circuitry of the battery, and the system it powers.
    Can you check some of the relays at the hood area, and see if you can replace them?
    Also check the fuse at the 12volt battery location, in the truck for shorts.
    Radio goes ? From your explanations here, this is a typical case of radio harness wires/contacts having partial contacts.
    Unplug the connectors, etc, and inspect for corrosion, or an improperly connected connector.
    Dxta
  8. Mendel Leisk
    38,664
    Normal parasitic loads would be around 20 milliamperes.
  9. Dxta
    Dxta Senior Member
    1,932
    766
    Lagos
    Exa
    Exactly! In some cases I have seen with Honda cross tours, it even goes beyond that.
  10. maverick4u
    usa
    2003 Prius
    I
    Ok thanks. I'm in illinois
    Thanks. I'm in Illinois which can have some really rotten winters. So how exactly does the aux battery charge? The Prius doesn't have an alternator so the inverter that feeds from the hybrid battery? So if the hybrid battery is going out then will it cha
    Wow-thanks for all the feedback guys. Gonna take me a while to digest all this information. I guess the first question I need to answer is whether or not this 2003 Prius is even worth fixing.
    I ran a "health system" check with techstream and I got about every DTC in the book: P1436, P3191, P3000, P3101,P3030, C1202,C1259, C1521, C1522. I will try to upload the file.
    If anyone can translate I would appreciate it! I noticed on the report it generated it said "Engine and ECT DTC=P1436, FFD=No...what does FFD mean?
    Health Check Techstream 2003 Prius.JPG ciate it! :)
  11. Dxta
    Dxta Senior Member
    1,932
    766
    Lagos
    I like the snapshot you took on the Heath check. How did you do that on the laptop, pls? I have tried getting a snapshot like this from my laptop, but it just isn't working. Could you explain in some bit? Or did you snap that with your phone, refitted and posted here?
    #11 Dxta, Dec 15, 2017
  12. Mendel Leisk
    38,664
    With older windows versions, alt print screen will capture current widow, place it in windows clipboard as an image file. With win 7 onward, google:
    Windows snipping tool
    SFO likes this.
  13. maverick4u
    usa
    2003 Prius
    I
    Yep...I used the "snipping tool" on my ancient windows 7 machine but I believe windows 10 has it too. Or you can use Ms paint.
    So anybody know how bad this 03 is? I was going to get a replacement Hybrid battery but now I'm not so sure with all these other trouble codes...:(
  14. TMR-JWAP
    TMR-JWAP Senior Member
    6,200
    5,897
    Columbia, SC
    Check out the P3030 for the HV battery. Click on the snowflake icon next to it and look at the block voltages that should be saved. The P3030 (iirc) says that one of the sensing wires is bad (most likely corroded through/broken off), but after 2 years of sitting, maybe just a really low voltage on some modules.
  15. dolj
    dolj Senior Member
    7,634
    3,850
    Wellington, New Zealand
    FFD = freeze frame data. = NO means there is no freeze frame data. If you look back at the screenshot you uploaded in post #10, 5 out of the 9 DTCs have a snowflake icon to the left of the DTC. This indicates that there is FFD. No snowflake = no FFD.
  16. maverick4u
    usa
    2003 Prius
    I
    Thanks for this informative video. Sure enough, the Prius has a 1.65 amp parasitic draw coming from somewhere. Now I just have to figure out from what and where. Is there a chart somewhere that tells me what fuse goes to what? They don't seem to be marked on the Prius. Thanks!
  17. dolj
    dolj Senior Member
    7,634
    3,850
    To reiterate a point he made in the video, the Prius is one of those cars (luxury??) he mentioned where you have to wait for it to "go to sleep" or quiesce (to use the technical term). IIRC it takes about 20 min, but give it 30 to be safe. During that 20-30 min some things shut down and you should see it drop at those stages. Remember, you need to have all doors closed (and your OP indicates you do not have SKS, so won't mention anything to do with that) and your timer starts from then. You therefore need to be able to see you ammeter without disturbing the car.
    The reason I mention this, is the current you mentioned (1,65 A) is about what the car is when you open the driver's door, i. e. everything off but not quiesced. The first drop will drop to about 50 mA then then after 30 mins it should finally drop to the quiesced state of about 20 mA. If it is a little more but still under ~50 mA, I wouldn't worry.
    Finally, if you don't find any circuits that are drawing unusually high after doing the fuse pulling, you need to consider what is preventing the systems from quiescing.
    #17 dolj, Jan 9, 2018
  18. Mendel Leisk
    38,664
    Ours was around 16~20 milliamperes, with regular, say every 15 seconds or so, spikes to around 40.
  19. dolj
    dolj Senior Member
    7,634
    3,850
    Your what and under what circumstances?
  20. Mendel Leisk
    38,664
    12 volt, monitoring milliamperes with a multi meter in series, all doors closed, car off for about an hour.
