12V BATTERY KEEPS DYING
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Biggiejuke, Feb 15, 2019.
  1. Biggiejuke
    Biggiejuke New Member
    Sweden
    Hello,
    Why does my car battery keep dying? If I don't start the car within 24H it will fail me the next day.
    It's a Toyota Prius 08 Gen 2. I have replaced the car battery a week ago, but the issue isn't fixed.
    I have some components in the car that are on all the time, but the mechanic says that they drain very low power. Is the 12V/45 Ah battery this weak?
  2. Biggiejuke
    Sweden
    Components drains like 70 mA at 12 V, less when car is turned off but I really do not know how much less.
  3. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    You have a parasitic drain somewhere
    51,141
    yes, it is extremely weak, because it only has to fire some relays and computers, no engine cranking.
    prius battery is too small for the component draw. mechanic is thinking about a normal car battery.
  5. Leadfoot J. McCoalroller
    7,856
    7,324
    Pennsylvania
    2018 Prius c
    You need to hang an ammeter on the battery, read the drain, then pull fuses until the drain drops to an ordinary background level. Whichever fuse makes that difference... the problem is on that branch. Narrow it down from there.
  6. Greenteapri
    Greenteapri Active Member
    330
    387
    Cypress
    From my fellow Houstonian.
  7. GrGramps
    GrGramps Active Member
    294
    176
    Western North Carolina
