12V Battery Life/Failures
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by triumph1, Nov 12, 2009.
  1. triumph1
    triumph1 Member
    275
    Tell us how long yours has lasted, or what age/miles yours failed.
  2. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Mine never really failed but it was starting to drain down faster than when new so I likely had comprimised cells.
    I swapped mine for an Optima last spring for a lifespan of about 3.5yrs and over 80k miles. To be fair, I have a very high wattage stereo system so I beat the poor batery to death!
  3. ceric
    ceric New Member
    1,114
    53
    Fremont, CA
    Mine lasted for 5 years w/o failure.
    However, I replaced it at dealer for $182 just to let my wife have piece of mind.
  4. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    After having mine changed within the first three months, my aux is going on 4 years and 9 months.
  5. uvm1969
    uvm1969 New Member
    39
    I have 132,000 miles on a 2005 and the battery is original and going strong.
  6. don_chuwish
    don_chuwish Well Seasoned Member
    816
    182
    Southern Oregon
    Can't be sure, bought my 2007 used this spring. But assuming it's the original battery, 2+ years and 21,000mi.
  7. Sandy
    Sandy Hippi Chick
    860
    53
    Ocala,Fl
    5.5 years was still working but had gremlins in the starting of car, one bad cell.
  8. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    The original battery lasted ~ 3 1/3 years (May 06-Sept 09). IMO the 2nd battery lasted 10 weeks.
    At 8:15 I locked the car with the SKS. At 17:30 SKS doesn't work, the fob doesn't work, and zero lights when the door is opened. After 3 tries the car boots up & all the presets are lost. Car runs fine to dealer & battery is charging at 13.5-13.6v. At the dealer voltage drops to 12.1v after the car is turned off. Left car doing its impersonation of a brick at the dealer.
    Didn't think to look for DTC.
  9. uart
    uart Senior Member
    4,215
    1,200
    Australia
    So Jim you had the battery replaced in September and it only lasted 10 weeks. Ouch that must be record for the shortest lived battery. Hopefully it was just a faulty battery and the it's not something else wrong with the car.
    BTW I recently bought a 2004 model used prius and I think it's still on the original battery and it still seems ok. Of course I can't be totally certain that it's the original, but I got the full service records with the car an I don't see any battery replacement.
    Dumb question I know, but the OEM battery looks to be "zero maintenance" is that correct. Is there really no way I can check the electrolyte level in this battery?
    Thanks.
  10. Patrick Wong
    18,200
    6,471
    If your car has an original equipment GS Yuasa battery, then it is supposed to be absorbed glass mat. If the battery indeed is AGM, then there's no free electrolyte to check.
    If you want to look in the battery anyway, you could peel off the label on top of the battery, which covers a translucent plastic rectangular cover. (The label contains a warning not to remove it.)
    Then pry up the cover and you will see into the six cells. If AGM you should see the battery plates and fuzzy white mats between each plate.
    Responding to the OP's question, I replaced the 12V battery on my 2004 with 92K miles in late October of this year, as a preventive measure. The battery was almost six years old and was still operational. The replacement was purchased from a Toyota dealer in Tucson.
  11. PA Prius
    PA Prius Active Member
    754
    241
    SE Pennsylvania
    '04, 122,500 miles and original battery still doing fine.
    PA P
  12. bsilver386
    bsilver386 New Member
    Burlingame CA
    Picking my car up following 90K check my MPG immediately dropped 10%. Any clues?
    Bsilver386
  13. bsilver386
    Burlingame CA
    After picking up my '05 prius from a 90K service I immediately noticed a 10% drop in MPG. Serviceman said the "computer needs to adjust itself in a couple of weeks" ???
    BSilver386
  14. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Check the oil level and tire pressures.
    Tom
  15. jdenenberg
    jdenenberg EE Professor
    3,850
    1,843
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My 2004 is at 161,500 with the original 12v battery. I have a jumper battery that take with me in my travels. I have used the jumper (it is also an air pump) 7 times, but not yet needed it for my Prius.
    JeffD
  16. bsilver386
    Burlingame CA
    Thanks,
    Never checked the oil, where's the dipstick??
    B386
  17. Genoz World
    Genoz World ZEN-style living
    797
    La Canada
    when you open the hood, look to the middle left. going by memory, the handle of the DS is yellow.
    mine was bought in 2/08 and i've got 35,000
  18. JimN
    7,028
    1,116
    South Jersey
    The battery is tucked into the right rear corner below the deck. Instead of a visual inspection I recommend the diagnostic screen on the MFD.
    Well, I'm honored that I set the record for shortest 12V battery life. If there is a contender I'll look up the exact dates. The only code was CP17. Toyota ate the cost as this was replaced under the replacement battery's 1 year warranty. The car doesn't "feel right" & my trip home was 6-8mpg below average. I'm checking the tp in the am & I have to reconnect my ScanGauge cable. I don't know who worked on the car but he relocated my cable trapping it in the dash.
  19. N3FOL
    N3FOL Member
    891
    16
    Stewartstown, PA.
    So far so good on this end for my 12V battery. Bought my '08 in Nov. of '07 and currently have 23K + miles on the odo. No aftermarket stereo, but I do run a mobile rig for amateur radio. Just like P. Wong, I may go ahead and replace the battery within 4 or 5 years time.
  20. josemedina
    josemedina Junior Member
    25
    San Antonio, TX
    I just got a new battery for my 2006 with 60,000 miles on it. My original battery only showed 6.4 volts and was out of warranty.
    I called Bernie out in California and a new better battery showed up in 2 days.
    All for $159.00 delivered. Check out his informative web page and see what I am talking about. Optimum battery to fit Prius with installation kit included.
    [FONT=&quot]http://www.elearnaid.com/12vo1topraub.htm[/FONT]
    800 236 1831 ask for Bernie and tell him that Joe from Texas posted his web site and phone number on this forum.
