12V battery maintenance
Discussion in 'Gen 2 Prius Technical Discussion' started by iralyons, Dec 31, 2008.
  1. iralyons
    iralyons New Member
    Brooklyn, NY
    I have a 2008 Prius, pkg #5. It gets used about once every 2-3 weeks in the winter. Is there maintenance to the 12V battery that will help it to maintain a charge? I have a portable, re-chargeable 12 V battery pack, JNS Jump-n-start (400 cold-cranking amps). Can this be used to charge the Prius' 12 V battery?
  2. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
  3. richard schumacher
    7,663
    1,038
    United States
    Turn off the smart key system (SKS). If you drive it at least 30 minutes every two weeks that should be sufficient to keep it charged, although the total life of the battery may be somewhat reduced. Judging from reports here it appears that about four years is typical life in a cold climate.
    If there are any after-market electronics installed that you can't disconnect and which may present additional loads it would be wise to put a battery tender on it. Your JNS will get you going if the battery dies, but I believe it won't keep the battery charged.
