12V Battery ?'s
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by s1njin, Jan 15, 2011.
  1. s1njin
    s1njin New Member
    106
    Sellersville, PA
    Hey guys,
    Just wondering about this battery - I've seen a bunch of threads about it failing. Is there anything special I'm supposed to do w/ this battery? Is it common for them to fail? Should I expect to have to have it replaced at some point?
    Since its a battery, and not the hybrid drive battery, I'm assuming its not a warranty situation right?
  2. Teakwood
    Teakwood Member
    491
    73
    New Mexico
  3. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Don't overly worry about the 12v battery. As the guy above has said, they'll last 3 - 5 years which is in line with a normal car. However, if you ever run them completely flat they do seem more prone to damage and will cause weird happenings when faulty.
    One other thing, if you're ever going to jump start the Prius be VERY careful about how you go about it. Refer to the owners manual about where to connect the leads etc or you could fry the computers which is an expensive mistake.
  4. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    It is not that the batteries are especially bad, it is that as owners we have no experience detecting dead batteries, except when they run a starter motor, and in the Prius the 12 volt battery doesn't.
    We need new skills at detecting dead batteries, and we are slowly getting them.
